200tdi VDO tach settings - Defender Source
Old December 16th, 2009, 06:07 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does anyone with a 200tdi and a VDO tach know which switches on the back should be switched?
Or at least what a revs a 200 idles at?
first was 5800
second was 1000
3 try was about 700
Old December 16th, 2009, 06:59 PM
Rugbier's Avatar
Rugbier
Gustavo
Tom,
Please let me know what you find out, as I have all new Bright green VDO for Pyro, Temp, Fuel,Oil, But a dull Speedo and Tach, and was wondering wich part number will make my dash look even.
NO SIGNATURE
Old December 16th, 2009, 07:52 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tach is 333-156 (4000 rpm) or 333-158 (6000 rpm)
I think the settings for the 3 switches are
up
down
up
Maybe someone can confim the settings
After you have the proper switch settings there is an adjustment on the side of the tach. My understanding is that you use a timing light connected to a petrol car with tach, connect timing light to spark plug wire, put mark on your dampner, rev car to 1000 RPM, rev your diesel so the timing mark matches the light and adjust your tach to 1000 RPM
Make sense?
Rug,
You know you can buy the little green condoms and slip them onto your bulbs and the color will match. I might have a couple of extras since I am going to install blue LEDS in mine
Old December 16th, 2009, 09:13 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Ever heard the saying: "I asked for the time and he told me how to build a clock".
Does your engine idle normally? Okay, that's 700 rpm give or take. Get the tach to read that at idle.
Done. Now have fun bouncing off the tach.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 16th, 2009, 09:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thats what I was hoping to hear, it is at 700.
I wasn't sure what normal idle was.
Old December 16th, 2009, 09:38 PM
Rugbier's Avatar
Rugbier
Gustavo
Dave,
I had no clue nor any idea where to get, so when yo uhave a chance eitehr let me know if they are available or where to get them
Originally Posted by dave_lucas
Rug,
NO SIGNATURE
Old December 16th, 2009, 09:39 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
ohhhh...k
guess I am just anal and would want to know what the true RPM's are vs good enough.
Old December 16th, 2009, 09:42 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I followed the good enough route. Flipped the switches until I got around 700RPM. Easy and quick.
Chance
Old December 16th, 2009, 09:44 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Gustavo,
I will check my garage tonight and see how many I have. You can also buy them form most places that sell VDO.
car part stores sell new bulbs in diffrent colors as well.
Old December 16th, 2009, 10:11 PM
Rugbier's Avatar
Rugbier
Gustavo
Dave ,
don'r go to the trouble , so what are they called? Bulb Condoms? I can see myslef getting locked up for disturbing the Peace in a Public Place
Gustavo,
NO SIGNATURE
Old December 16th, 2009, 10:57 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
http://www.egauges.com/vdo_acce.asp?...users_Type_E/C
I doubt that you will find the diffusers in an auto parts store but they will sell bulbs in diffrent colors
Bulb type is 194
You can also get LED bulbs
http://www.superbrightleds.com/cgi-b...%2FWLED-x6.htm
Old December 16th, 2009, 11:06 PM
Rugbier's Avatar
Rugbier
Gustavo
Thank you
Order placed
NO SIGNATURE
Old December 17th, 2009, 09:45 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
ohhhh...k
Nothing wrong with that. Although I really can't imagine any circumstance where thinking you are at 3000 rpm and really being at 3010 would matter.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 26th, 2011, 05:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What dip switch settings did you end up with? Mine are: off off off (all down) and idle shows 1100 RPM on the new VDO tach. The idle is "normal" so I'm wondering what setting would lower the reading. I have tried many different settings.
Old June 26th, 2011, 11:16 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Seems like it was off, off on. But that was a while back and I'd have to disassemble to confirm.
Chance
Old June 27th, 2011, 12:07 AM
After you get closish with the dip switches, you need to adjust with the screw on the side. Get a laser tach and set it properly. They are cheap.
Old June 27th, 2011, 01:33 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where do you put the reflective mark for the laser tach?
Old June 27th, 2011, 08:47 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I had mine set to the, about, 700 rpm. The main thing is not what it reads exactly but what it does after you drive it for awhile. You will soon find the normal and when it goes outside of the normal you will know something is up. The VDO takes the reading from the tach so you will never be able to get it exact no matter what you do.
Land Rover 110
Old June 27th, 2011, 08:51 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm going to order a laser tach. The reading on the new VDO is a lot higher than my old tach so I assume it needs to be adjusted. It bottoms out at 4000 quite often during normal driving. Doesn't seem right to me.
Old June 28th, 2011, 12:02 AM
The harmonic dampener is a good spot.
200tdi, ac, tdi
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
