200tdi VDO tach adjustment? - Defender Source
Old October 22nd, 2013, 06:48 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anyone know how to get a rough idea of what the engine is running at on a 200?
I've messed with the 3 toggles on the back of the tach, but still can't seem to get it right.
I thought I had the idle right(800-900rpms) but it seems to climb very fast. Is there a way to tell the rpm without the tach
Old October 22nd, 2013, 06:58 PM
There is a screw on the side for fine adjustment. The switches are just for very coarse adjustments. Assume idle is 700 rpm to get in the ballpark.
You can check fairly well if you know your gearing and and use a GPS for speed. To get exact setting a laser tachometer is the easiest way. They are quite cheap.
Old October 22nd, 2013, 07:02 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
"Lazer"
Great thanks.
Old October 22nd, 2013, 07:17 PM
Ztimulated?
200tdi, ac, tdi
200tdi VDO tach settings tomaco1 Defender Technical Discussions 23 August 4th, 2011 09:16 AM
Small Tach Gauge For 200TDI isleofbones Wanted 10 April 21st, 2011 08:10 AM
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 04:55 PM
200tdi VDO gauge #'s tomaco1 Defender Technical Discussions 9 March 18th, 2009 11:06 AM
