200tdi VDO gauge #'s - Defender Source
Old February 8th, 2009, 08:24 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I've gotten various numbers for gauges (VDO) and Senders. Some confusion with V8, 300tdi, etc.
I was wondering if anyone has Part numbers for the 200tdi gauges?
H20 Temp:
H20 sender:
Tach:
Fuel:
Boost:
Boost Hose Kit:
Volt:
Voltmeter Extras Needed:
Oil Pressure:
Oil Presure Sender:
Exhaust Gas:
EG kit #:
I have found many numbers by searching, but didn't want to cloud the issue!
Old February 8th, 2009, 10:23 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tom,
Is there a reason that you can not use the stock gauges?
Just wondering since our truck are almost the same and I will be adding a 200TDI when it arrives.
Old February 8th, 2009, 11:10 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Beyonce said it best!
Let me,Let me Up-Grade-YA
Old February 9th, 2009, 07:19 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Tom, I just did all that to the Brewers truck with a 200 in it. All VDO http://www.egauges.com/vdo_grou.asp?Series=Vision Very easy to figure out what you need on this site.
Don't have the part #'s in front of me. The only bit that was at all challenging was adapting the coolant sensor for which I had to make my own part (modified stock sensor).
Matt Browne
Old February 9th, 2009, 10:39 AM
Disco or Defender TDI?
For the Defender 200TDI.
Water Temperature sender: 323-026 (5/8-18 UNF) is a direct fit. Gauge is 310-105 (Imperial) or 310-010-002K (metric)
Boost is 150-101 (15 psi) or 150-104 (30 psi)
Fuel is 301-105
Tach is 333-156 (4000 rpm) or 333-158 (6000 rpm). 4000 rpm is fine....
The rest I use other gauges.... IMO, the best choice is the Madman gauge kit for EGT, oil pressure, coolant level, voltage, http://www.madman.co.za/
Old February 9th, 2009, 11:00 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does the Boost need a Hose Kit?
Old February 9th, 2009, 12:25 PM
Originally Posted by tomaco1
You need to figure out plumbing one way or the other.... Note there is no port on a 200TDI, so you need to drill and tap the intake manifold. The 150-851 on egauges should be fine.
Old February 9th, 2009, 07:16 PM
Tom,
You didn't say what you want VDO Vision or Cockpit series. Different part numbers. I used Visions and love em
Old March 16th, 2009, 03:48 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Just an FYI. Disco 200Tdi engines do not have 5/8" UNF temp senders in them. I actually found and purchased a 5/8" UNF Male to 1/8" NPT Female adapter, which didn't work. Don't know what the stock sender is, but it's pretty fine threads. I've given up on an adapter and am going to drill and tap my stock sender to 1/8" NPT.
Chance
Old March 18th, 2009, 11:06 AM
J4hand
James Forehand
83 110 200tdi
On the Disco 200tdi temp sender, I found the thread size was 16M with 1m pitch, very fine. I too tried the 5/8 adapter with the vdo 1/8 NPT sender. It doesn't work. I drilled out my sender and tapped it for the 1/8 NPT sender. It worked great and I used the little rubber o-ring in the old sender as a gasket for the vdo sender.
200tdi, tdi
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 04:55 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 04:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 09:36 AM
