200TDI valve cover leak - Defender Source
Old April 12th, 2015, 09:49 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I've got a leak coming from the joint between the valve cover and the head. I've replaced the gasket and that didn't get it, then the half moon rubber seals at front and back, but it's still leaking. It appears that the valve cover is being pressurized, because I when I increase engine rps I can watch the leak grow. Would a clogged breather cause this? It's making a mess of the whole engine so would like to get it fixed.
Old April 12th, 2015, 09:52 PM
Yes check that the breather is clear.
Old February 4th, 2017, 10:40 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Hey guys! Same truck, new owner, still having the same issue. May be a dumb question but I'll just ask it ... how do I check the breather for clogs? Any advice? Thanks!
Old February 4th, 2017, 11:31 PM
Suck on it and see if air flows through.
200tdi, cover, tdi
200 Tdi Valve Cover... Cover ERR3276 BlackField Wanted 0 March 22nd, 2014 09:58 AM
200tdi valve cover bolt gasket problems dave_lucas Defender Technical Discussions 15 November 16th, 2009 06:49 PM
200tdi valve spring tension draaronr Defender Technical Discussions 1 August 11th, 2009 10:43 PM
200tdi valve clearances Hoosier Defender Technical Discussions 6 March 18th, 2009 12:45 PM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
