200tdi vacuum pump delete - Defender Source
Old May 5th, 2013, 12:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Can I remove the vacuum pump, leave the shaft and seal/bolt a plate to delete the pump?
Or... is there anything I'm overlooking here such as oil pressure.... or ?
Old May 5th, 2013, 12:45 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Is it different from the 300tdi's cam lobe driven one?
Old May 5th, 2013, 12:50 PM
D90user's Avatar
D90user
steve
yep. shaft driven
Old May 8th, 2013, 12:35 PM
D90user's Avatar
D90user
steve
bimp....one of you tdi experts must have some input
Old May 8th, 2013, 04:10 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
What are you going to do for brake vacuum?
Mike Hammond
Old May 8th, 2013, 04:34 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
you will to support the top of the shaft with a plain bearing machined into the blanking plate, if you must why not take the vanes out and blank off the hole?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 8th, 2013, 04:50 PM
D90user's Avatar
D90user
steve
Motor is in a series 1 with no power breaks ( I did go wildwood dual circuit though)... so no vacuum needed.
It seems like just removing the vanes is the simplest... I just wanted one less moving part and less chance of sucking somethign nasty in to my block.... but it is seeming like a PITA to delete it.
Can I remove the whole shaft?
Old May 8th, 2013, 05:11 PM
Jut run the hose to the valve cover or such. It discharges the air to the cam gallery, If you read the description, you would want to be careful removing the vanes as oil is pumped in behind them.
Old May 8th, 2013, 05:30 PM
D90user's Avatar
D90user
steve
What about putting a breather filter on in and calling it a day?
-Jeff
My understanding is that if it is allowed to suck freely it can cause excess pressure in the block.
Would removing the vanes cause any problem though?
Old May 9th, 2013, 03:16 AM
mikeslandrover
Mike Hammond
Reading the description routing from the rocker cover wouldn't cause overpressure, it would suck from the engine internals and return to the engine internals. You might want to put some sort of restriction so that it's not pumping at full whack all the time.
Reading the description I don't think removing the vanes would be a good idea as it mentions checking an o ring in case of low oil pressure.
Just my take on it.
What about fitting a remote servo?
You'd get a useful brake up-grade.
Mike Hammond
Old May 9th, 2013, 06:25 AM
rovertrader's Avatar
rovertrader
Dale
Steve- I have no input on the subject, sorry- but interested to find the solution...
However, I could use the pump should you be able to sell it when you are done.
Old May 9th, 2013, 11:01 AM
D90user's Avatar
D90user
steve
Mike- I agree that routing to the rocker cover would cause no harm.
I did look into a remote booster, but they are expensive for dual circuit. Plus im trying to keep this truck as simple as possible. I kind of enjoy the non boosted brakes on my 911... so we'll see if they are as fun on a S1.
I really like to get rid of it but I guess I'll just revisit this later and if I do I'll let you know rover trader.
Old May 9th, 2013, 12:11 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
On my 2.5na I just capped mine with no ill effects.
Old May 9th, 2013, 01:40 PM
roverman2010
1985 LR 90 200Tdi
look up brake servo vacuum pump bulletin, RR3950M
Tells of occurring low oil pressure if "O" ring is damaged. find your self a 200tdi engine rebuild manual.
this "O" is fitted into the vac pump.
You are on your own removing the Pp
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old May 20th, 2013, 06:38 PM
Apocalypse Vehicle
Evian Degree
none yet
wilwood
LOL I just got my series II 200tdi project going down the street after a year. I couldn't figure why my new engine was blowing so much oil past the oil fill cap on the rocker cover. After messing around with it for a couple days I figured out it was that damn pump sucking air inside the engine. I had a breather on it so took that off and plugged it up and she's not leaking now. Had me worried for a couple days as it's a newly rebuilt engine. Did you change to wilwood pedals as well? I'm thinking about using their pedal assemblies, if it will make more leg room. i'm tired of raising my knees to the roof to get on top of the pedals. I used the defender throttle but I also want to change that if I can get something in a better position and still have clearance for full throttle. I had to tweak it to mount to the bulkhead and after driving it for a week I'm not happy with it's position.
Old May 21st, 2013, 01:23 PM
D90user's Avatar
D90user
steve
This is on a series 1 so it has floor pedals. But I did use a wilwood dual brake master.
I just bled it and it gets nice firm pedal... but no road test yet
200tdi, vacuum
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
300tdi Vacuum Pump navydevildoc Defender Technical Discussions 9 June 30th, 2011 08:11 AM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
