200tdi timing belt change - Page 2 - Defender Source
Old September 24th, 2012, 04:02 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Made some progress today. Got everything torn down to find that the belt was disintegrating due to a siezing idler bearing. The timing case was filling with minute pieces of rubber as the idler allowed it to chafe (the idler was losing it's grease). I didn't order an idler originally but have one on it's way now. Obviously I'm relieved to have found this.
I'm still baffled that none of the domestic sources offer this timing kit, though. It seems like there are a lot of us running 200tdis over here and having a single kit of timing belt, tensioner, idler, gaskets and even the water pump and belts seems like a no-brainer kit to have on the shelf.
Old September 24th, 2012, 04:13 PM
Naplm00
Matthew
Do you have a disco or defender? I have a disco idler laying around i think
Old September 24th, 2012, 04:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
disco.
Old September 24th, 2012, 04:21 PM
Naplm00
Matthew
need it?
Abrooks's Avatar
Abrooks
Tony Brooks
I'd love it! PM coming, thanks!
200tdi, tdi
200tdi oil leak timing belt tens pulley pivot kjva Defender Technical Discussions 5 September 28th, 2011 03:18 PM
shop to change timing belt 300tdi - DC Metro area hillstrubl Defender Technical Discussions 17 July 19th, 2010 06:39 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300tdi timing belt change now problems discotdi Defender Technical Discussions 57 June 4th, 2009 10:10 PM
