200tdi theromostat housing removal - Defender Source
Old October 3rd, 2013, 10:16 PM
kjva
Ken Jackson
1985 110 Wagon
Have a 200tdi with a stuck thermostat. When removing the housing the bolts sheared off and will need to be drilled out.
To remove the housing the head should be removed as the engine has just been rebuilt I am reluctant to do that.
Looking at other forums the bolts are 2mm lo long. I was thinking of cutting them getting two new bolts and milling 2mm off them.
Can anyone see a downside with this.
Old October 3rd, 2013, 10:26 PM
All three bolts sheared? Can you use sone heat and a lefty drill bit to try and remove what's left of the bolts? If the bolts are all sheared then doesn't the housing come right off ?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 3rd, 2013, 11:13 PM
Are you sure the head needs to come off?
Old October 3rd, 2013, 11:47 PM
kjva
Ken Jackson
1985 110 Wagon
The bolts holding down the top of the housing sheared they were 10mm heads.
By the look of them they had bee on there a very long time.
I would have thought when the engine was rebuilt the thermostat was checked.
They will need to be drilled out I could do it in situ but is better if I can get the housing off
------ Follow up post added October 3rd, 2013 11:50 PM ------
Yes I looked on the UK forums and several commented what a bad design it was.
One guy milled off about one mm on the timing cover and one mm off the bolts and they would fit.
Old October 4th, 2013, 08:15 AM
Can't you unbolt the housing from the head? I recommend using extreme caution/patience/PB blaster and tap the heads with a small hammer to loosen them up. Oh and heat too.
Present:
1987 RRC- "Chewy 2"
Past:
Old October 4th, 2013, 08:47 AM
kjva
Ken Jackson
1985 110 Wagon
The top bolt yes, the bottom two hit the timing cover and can not be removed.
That is why I am thinking about cutting them and milling 2mm off the new bolts.
One post on a UK forum suggested milling 1mm off the timing cover and 1mm off the bolt heads.
Another post the guy had rebuilt the motor and fitted the head and omitted the thermostat housing to find it could not be fitted with the head in place.
Old October 23rd, 2013, 03:16 PM
kjva
Ken Jackson
1985 110 Wagon
Cut off the two lower bolts found some slightly shorter ones in NAPA had to grind a little off the heads off them to make it work.
For the top cover found the right bolts in Tractor Supply.
200tdi, tdi
200tdi thermo housing roverman2010 Wanted 2 April 25th, 2013 02:17 PM
Ram housing removal scolvus.x Defender Technical Discussions 3 March 27th, 2013 08:22 PM
Wanted: Flywheel housing (Cover) for 200tdi Macker Wanted 3 July 18th, 2012 06:53 PM
In situ gear selector housing removal michael67 Defender Technical Discussions 4 September 25th, 2011 12:34 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
