200TDi Thermostat Question: can a V8 82C be used? - Defender Source
Old July 8th, 2013, 05:45 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Hola one and all. I have tried searching so as not to waste anyones time but haven't found any answers.
I have a 200TDi with a 82C thermostat in it which looks like this:
(first image, no round plate at the bottom, just the brass slug looking thing. Works fine, been tested and tested in pot of water with thermometer)
I have seen that all of the 200Tdi stats for sale are 1. 88C and 2. look like this:
(second image, round plate at the bottom)
Any issues with running the 82C one that I have in there or do I need to change it? My temps are running about right, 190-200 on hot days, getting up to 210 up a hill on the freeway(found out the viscous fan wasn't working so new one on order)
ID:	75555   Click image for larger version
Name:	200tdi thermostat.jpg
Old July 8th, 2013, 10:08 PM
You must have the second type. The lower disc is a valve that closes the bypass flow. Without that disc, very little coolant will flow through the radiator.
Old July 8th, 2013, 10:10 PM
El Solis's Avatar
El Solis
Chris Solis
Yeah I had a feeling that was the case. Thanks!!
200tdi, thermostat, v8
200Tdi and LT230 Gear Ratio Question newfD90 Defender Technical Discussions 33 June 1st, 2016 02:30 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Alternator wiring question 2.5 NAD to 200tdi dave_lucas Defender Technical Discussions 6 December 3rd, 2009 12:01 PM
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
