200tdi tach - Defender Source
Old November 5th, 2008, 06:08 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
200tdi tach
Can anyone point me at a doc on adding a tachometer to a 200tdi?
Old November 5th, 2008, 07:18 PM
Your 93 is prewired just get the tach and hook into the multiplug in the wiring harness behind the instrument binnacle. Check the wiring diagram for the correct pin.
Old November 5th, 2008, 07:25 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I'm looking into doing this for my 200Tdi as well. Best I've been able to figure out is to wire the tach up to the W terminal of your alternator. Then (at least on the VDO tachs), there's some switch settings you have to fiddle with on the tach to set the right amount of pulses/revolution.
I've been looking at either the VDO 333-156 or 333-158
Here's the VDO instructions: http://www.egauges.com/pdf/vdo/0-515-012-044.pdf
Edit: Ooops didn't notice you're in a 93. Doug is right. My 83 isn't wired for one.
Chance
Old November 5th, 2008, 07:26 PM
ajh
Andrew J. Hutton
Sorry I should have said that it is on a 1992 110, I guess if I get the 1993 parts catalog I can find the relevant bits then.
Old November 5th, 2008, 07:31 PM
The 200tdi uses a plug on the back of the alt to make the different wiring connections. The w terminal is covered by this plug and that signal wire runs into the truck behind the instrument cluster. Just check the wiring diagram for the correct wire color/code pin orientation. Easiest is the stock gauge but one that can be adjusted to the alt signal may be cheaper as Chance pointed out.
Old November 5th, 2008, 07:36 PM
ajh
Andrew J. Hutton
Thanks, this helps a lot. There is no place for a stock gauge right now but my plan is to pod all the new gauges until I do the rhd to lhd conversion then just make a new dash.
Old November 5th, 2008, 07:42 PM
VDO model 333-156. Run a wire from the tach and adjust. Simple, looks so good, you will want to replace all of the instruments...
ID:	16183   Click image for larger version
Old November 5th, 2008, 08:01 PM
What did it take to make the fuel gauge work? Did you buy the VDO sender? If so, how did it install, and in what location is your fuel tank?
Old November 5th, 2008, 08:10 PM
Andrew I have a complete LHD drive dash- in better than average condition from a 94 NAS and was considering selling it.
I used the stock sender with a new VDO Vision fuel gauge and it works fine.
Old November 5th, 2008, 08:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
is the 300tdi wired the same Doug?
Legend in My Own Mind.
Old November 5th, 2008, 09:05 PM
ajh
Andrew J. Hutton
this sounds like a very good cantidate for a useful tech article
Old November 5th, 2008, 11:13 PM
Yep, it works perfectly with the stock sender. Model 301-105, 240 to 33 Ohm range
200tdi, ac, tdi
200tdi VDO tach settings tomaco1 Defender Technical Discussions 23 August 4th, 2011 09:16 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
tach question, sorry if redundant (warning) Neo Defender Technical Discussions 5 October 7th, 2005 04:24 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Tach works off and on mdmccallum Defender Technical Discussions 2 November 18th, 2004 07:25 PM
