200TDi Starter Replacement - Page 2 - Defender Source
Old March 1st, 2014, 06:54 PM
the engine wiring harness plugs into a multi plug on the firewall. Trace the red white wire back to that multi plug and unplug things and check it there. I have seen some scary amounts of green corrosion there
Old March 1st, 2014, 07:17 PM
BlackField's Avatar
BlackField
Oscar
D110
I had been testing the wire from the connector at the key the whole time never getting continuity. I decided to go the other way and plug in at the starter and work my way back had continuity everywhere even the relay that I didn't discover until the end. kept checking the wire in three places between the firewall and the connector and no continuity. I stabbed the wire an inch from the connector and had continuity everywhere. Stupid connector broke at a crappy crimp (not mine).
culprit:
repair:
In the end the truck started. I have a spare starter and a greater hatred of the mad crimper who worked on my truck.
Thanks everyone,
Oscar
Old March 1st, 2014, 07:56 PM
glad it was something simple. Sucks you had to get proficient @ replacing a 200 starter, that job sucks.
Old March 1st, 2014, 08:40 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm pretty sure I can drop and reinstall a starter in less than ten minutes now maybe 30 including the down pipe. Putting a new terminal on a single wire takes me two days though.
Old July 15th, 2017, 09:27 PM
BlackField's Avatar
BlackField
Oscar
D110
Talking
Well that starter that I installed in February '14 just STB, so it got replaced by a RDavisinVA 3.1KW starter that had been collecting dust on the shelf. That 3.1KW starter is awesome.
Pulled and replaced in 2 hours, I had to check on my 10 week old puppy or I would have knocked it out faster. Fun times, not really. Thanks again for all the help.
200tdi, ac, start, starter, tdi
Starter Swap 200TDi for V8? BlackField Wanted 4 February 24th, 2014 08:45 PM
200tdi starter problem...help! isleofbones Defender Technical Discussions 12 February 22nd, 2014 08:09 PM
New 200TDI / 300 TDI Starter Ncrover725 For Sale - Parts 2 November 22nd, 2013 09:58 PM
Clutchless Fan Replacement for 200tdi isleofbones Defender Technical Discussions 16 July 17th, 2012 02:42 AM
Locking Lug Nuts / 200Tdi Starter motor d90frank Wanted 2 March 7th, 2011 06:36 AM
