200tdi starter problem...help! - Defender Source
Old February 1st, 2014, 01:10 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Tried to start my '84 defender last week on a really cold day. It is a slow cold starter like many diesels. I cranked for a while and as engine seemed close to turning over when the battery died. Removed battery cables and charged battery... Battery now good. Now, when I turn ignition switch, the starter makes a click, but wont activate. I think power is getting to starter because it clicks, and because when I turn on headlights and then turn ignition switch, the lights dim. I guess I can take starter out and have it tested. Is the solenoid on the starter or separate in the fuse panel for the 200 tdi? Thanks for any help you can offer.
Old February 1st, 2014, 01:24 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
You might want to have your battery tested..
Old February 1st, 2014, 01:30 PM
This and clean off the cable connectors and the battery terminals.
Old February 1st, 2014, 01:37 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Battery terminal cleans ? ALL ground points good and tight/clean ? To insure your battery is a goner, try jumping the D with another vehicle. A few weeks ago, similar post solved with a Kat's battery warmer blanket (120 volt). A warm battery can make all the difference. eBay or Amazon http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old February 1st, 2014, 04:09 PM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
I happened to mine few weeks ago, turned out it was the alternator.
Old February 1st, 2014, 04:48 PM
isleofbones
Mike Deery
1984 D-90
Thanks for input. Battery is good... tested. Terminals and connections cleaned. Maybe next step is to remove starter and have it tested.
Old February 1st, 2014, 04:51 PM
Have you tried jumping the starter with jumper cables? Why pull the starter before you have ruled everything else out?
Old February 1st, 2014, 05:24 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Starters are simple devices, maybe just a good disassemble and cleaning is in order.
Old February 1st, 2014, 06:42 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Whack the starter with a hammer a couple of times and s
Old February 1st, 2014, 09:18 PM
Check your chassis ground as well.
Old February 22nd, 2014, 06:08 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm having a 200TDi starter issue also.
Truck has been in the paint shop for the last couple of weeks and when I went to pick it up it didn't want to turn over. No clicking, no drop on the voltage gauge. Jumped it with a battery cart and nothing.
I looked at this:
It doesn't seem like a very complicated system. Any one know where the relay is typically stashed? Any clue what else to check? The 200TDi doesn't lend itself to a good solenoid beating.
Oscar
Old February 22nd, 2014, 07:56 PM
The relay is with the relays.... Bottom of the fuse panel.
Old February 22nd, 2014, 08:09 PM
isleofbones
Mike Deery
1984 D-90
200tdi starter
Hi Guys-
Indeed, after testing, my starter was burned out. Got a great rebuilt valeo starter from Trevor (Roverlab) on this site (bargain priced at $200). Chris of Rovertek (also a site member) just installed it, and I am happily on my way again. It was quite a production to install as I have a disco 200tdi in a rhd truck. the exhaust pipe had to be removed and the engine actually jacked to get the starter out. I considered trying to tackle it myself, but I couldn't even touch one of the bolts with a wrench. Much thanks for advice of members, thanks to Trevor for a great starter at a good price and thanks to Chris of Rovertek for an expert repair, as usual. Can't wait to have Chris install my new rear crossmember.
200tdi, start, starter, tdi
New 200TDI / 300 TDI Starter Ncrover725 For Sale - Parts 2 November 22nd, 2013 09:58 PM
Starter problem GuamPilot Defender Technical Discussions 4 June 7th, 2013 09:34 AM
Locking Lug Nuts / 200Tdi Starter motor d90frank Wanted 2 March 7th, 2011 06:36 AM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
