200TDI Starter motor ordered TOO big - Defender Source
Old January 18th, 2018, 09:25 AM
ViperJames
James Forte
1991 Defender 90
Hey Guys, having some trouble finding the RIGHT starter motor for my car. I have a 1991 D90 200TDI. I ordered one from LDParts in the UK and its about 1 - 1.5 inches longer than the one that was in there and it doesn't fit but they seem to think it should. Anyone have this same issue? Any help here would be greatly appreciated. Thanks James
Old January 18th, 2018, 09:38 AM
Naplm00
Matthew
Never had this issue but pics/part number/measurements will help us help
You
Old January 18th, 2018, 09:40 AM
Chris B
72 + D1 drivetrain =?
Have you tried to get your current one rebuilt? Whats the part number they sent you?
Old January 18th, 2018, 09:43 AM
ViperJames
James Forte
1991 Defender 90
Thank you its Britpart # NAD500210. No have not tried to get current one rebuilt my mechanic never gave me that as an option, plus this part cost $88 so I figure that would be cheaper anyway. Any help is greatly appreciated. thanks
Old January 18th, 2018, 09:51 AM
correct part no. Who's telling you it does not fit ? Why doesnt it fit - hitting the down pipe ?
Old January 18th, 2018, 09:54 AM
I've only replaced my starter once and I replaced it with a cheap Valeo. It's given me no issues.
Here's the parts interchange page:
LAND ROVER DEFENDER Station Wagon 2.5 90,110 TDI Starter Motor Parts
Old January 18th, 2018, 10:04 AM
ViperJames
James Forte
1991 Defender 90
My Mechanic he had to take the exhasut off i guess he is saying that its a very small area where it goes in and he did show me the one that came out of the car and the one that i have and the new one is about 1.5 inches longer...
Old January 18th, 2018, 10:09 AM
I guess to answer your question, yes there are two different sizes.
ERR5009 is the smaller size.
Both should fit, though..in theory.
Old January 18th, 2018, 10:11 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Originally Posted by ViperJames View Post
My Mechanic he had to take the exhasut off i guess he is saying that its a very small area where it goes in and he did show me the one that came out of the car and the one that i have and the new one is about 1.5 inches shorter...
If you were sent a 2.5 N/A starter it is too big.
We have 2.2 KS starters in stock and will have some of the heavy duty 3.1KW starters in 30 days.
RDavisinVA
Old January 18th, 2018, 10:15 AM
ViperJames
James Forte
1991 Defender 90
Sorry i corrected the post the new starter i received model # NAD500210 which is a Britpart is 1.5 inches LONGER than what came out of the truck.
------ Follow up post added January 18th, 2018 10:17 AM ------
This would make sense, so you are saying the ERR5009 is smaller than the NAD500210? Sorry i just want to be 100% sure before i pull the trigger. thanks
Old January 18th, 2018, 10:26 AM
In theory.
Without photos of your problem, without actual documented evidence, I offer no guarantees.
No idea what your mechanic has, what was in your truck, what you received, what you expected, whatever. We have no idea what to go on except that you ordered a part, got something that was "too long" which makes no sense because all starters should fit.
Like I said, both starters should fit. It makes no sense that the NAD500210 starter doesn't fit. The Bosch ERR5009 and Valeo I know for sure are short, as the photos attached show.
No idea what Britpart is shipping when you order.
The problem is that some starters built by different manufacturers are using long-bodies under the same part numbers. It sounds like Britpart is selling long-body starters. So if you order from LRDirect and order ERR5009 and they ship you britpart, you'll probably end up with a long-body starter.
Old January 18th, 2018, 10:35 AM
ViperJames
James Forte
1991 Defender 90
In theory.
Thanks, i ordered the ERR5009 Part i even saw notes on another site that the ERR5009 is the "smaller" version. I am sure this will work. If not i will have stock for EBAY! Rovers North sells these parts for $430 when they can be purchased from the UK for less than $100. Sweet business! Thanks
Old January 18th, 2018, 10:38 AM
I'm sure it is fine. I've used bigger and smaller ones. There is no reason for them not to fit unless you have non standard exhaust. There is nothing in the way.
You must remove the exhaust to install.
That all said, buy the 3.1 kW one from Robert. They are great.
Old January 18th, 2018, 11:51 AM
Naplm00
Matthew
Do everyone a favor and when you get this new starter in can you take two pictures comparing them side-by-side and post it up
Old January 18th, 2018, 12:38 PM
For this reason, on my 1991 200TDI, I changed to a 2.5TD downpipe. It has a flange just after the elbow. It makes servicing in that part of the engine bay MUCH easier. It is less of a problem if your are RHD. With LHD, the area is very crowded.
Old January 18th, 2018, 01:12 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I think the longer starter should fit fine.
The issue is probably the mechanic has no clue, or someone did a transplant and the down pipe is restricting the starter.
If the pipe is as close that a 1.5" longer starter doesn't fit, then the old starter probably had the commutator end fried by the exhaust heat and the whole front exhaust needs to be rerouted.
RDavisinVA
Old January 23rd, 2018, 10:52 AM
ViperJames
James Forte
1991 Defender 90
Hi All thanks so much everyone for chiming in. I did replace the exhaust on this car with aftermarket but stock replacement, but the mechanic said he had to remove part of it to get to the starter so that is NOT the issue the space where the starter actually goes is too small for the bigger started. So the 2nd Starter i ordered is ALSO too big!! I have attached photos this time. the photos with the sticker and other photo with the stamp MSP1606 are both from the original starter that FITS. i have a side by side of the starter that fits next to one of the new ones that dont fit. Does anyone know what brand the starter is with the sticker and stamp? I googled it and nothing comes up. Thanks!!
ID:	348705   Click image for larger version
ID:	348721   Click image for larger version
Old January 23rd, 2018, 11:07 AM
Show us pictures of how they do not fit. What are they hitting?
Old January 23rd, 2018, 11:10 AM
I'm not a starter expert, but you have the shortest starter available. There's no way that the starter is the problem here
Edit: Um....waiiit a second. Are you sure you don't have a disco 200tdi? Because your old starter doesn't have the aluminum bumpout.
It still shouldn't matter though. Is it possible that your mechanic doesn't know what he is doing?
Old January 23rd, 2018, 11:31 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I'm with John B on this one.
Show us a picture of each starter mounted and what the specific interference is.
I think that huge bump-out is in the way and someone sent you a replacement starter for a 2.5 N/A.
If you bought this starter in UK, you could be SOL.
We have the correct fitting 2.2 KW starter in stock and the more powerful Heavy Duty 3.1 KW model due here on 2/18/18.
RDavisinVA
200tdi, motor, start, starter, tdi
1991 LHD 110 200tdi 5 door greenmountainrover For Sale - Vehicles 4 January 2nd, 2018 07:14 PM
200TDi Starter Replacement BlackField Defender Technical Discussions 24 July 15th, 2017 09:27 PM
Starter Swap 200TDi for V8? BlackField Wanted 4 February 24th, 2014 08:45 PM
200tdi starter problem...help! isleofbones Defender Technical Discussions 12 February 22nd, 2014 08:09 PM
New 200TDI / 300 TDI Starter Ncrover725 For Sale - Parts 2 November 22nd, 2013 09:58 PM
