200tdi spigot bush removal? - Defender Source
Old February 17th, 2014, 03:52 PM
Does anyone have a tip on how to remove the spigot bush on a 200tdi?
I just spent about an hour trying to use the "pack the hole with grease" and use various sockets and extensions and a hammer to hydraulically extract the bushing, but it is not moving one bit.
Any tips short of buying a puller?
Old February 19th, 2014, 02:12 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Ed, grease has worked in the past for me, however I've also hooked the edge of a hex bolt behind the bush then passed it through the hole in a socket and wound it out far enough to grip with mole grips and then twisted it out.
have also cut through the bush with a snapped hacksaw blade then used a punch to start it turning was then easy to hook out with a spring hook.
have also made a hook out of flat bar, clamped the end with mole grips and beat the shit out of the grips like a sort of hillbilly slide hammer - this has worked twice, but once gave me a huge bruise on my shin when I missed with the hammer.
regards
Gren
Old February 19th, 2014, 02:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Grease sucks for this. To hydraulically force it out, I pack the hole with wet toilet paper and use a close fitting punch wrapped with a few layers of electrical tape to provide a snug fit. This method also works very well to remove the blind bushing in a Discovery rear drive shaft with the rubber donut joint.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
200tdi, tdi
200tdi theromostat housing removal kjva Defender Technical Discussions 6 October 23rd, 2013 03:16 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
