For a variety of reasons I had to be a pocketbook mechanic for my top end rebuild. I finally got my truck back but it still needs some fine tuning.
Basically, I am seeing a noticeable black haze with any acceleration even with low rpms. Frankly, not sure if it is an issue, but is new after doing a bunch of work. Under hard acceleration it is a decent cloud. The egts are low with a max of maybe 850/900 on the highway at 65 ish. The boost is about 15. Max speed seems to be about 70 ish. Also, I have noticed that going from a stop is sluggish. I basically can't get moving until the turbo kicks in.
I'm fairly confident it has to do with the IP. Most of the engine has been overhauled with new injectors, header, head gasket, Alisport intercooler and radiator along with a VNT turbo.
I'd like to tackle this myself, but being newbie I am a little intimidated about the possibility of making things worse.
It seems like I have two issues - the low speed power and smoke under load. So do I start by turning in the smoke screw and then back off on the star wheel?
