200tdi runnin' a little hot - Defender Source
Old June 22nd, 2012, 12:25 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I am looking to bring down the temp of my defender in hot weather. The other day it was 98 degrees and the temp guage went up to the orange (hot) zone of the guage, but did not go into the zone and it did not overheat. My car runs cold in the winter, in the middle zone in moderate temperatures (50 degrees - 80 degrees) and hot when the temperatures go over 90 or so. I don't want to re - engineer the whole cooling system. Looking for some hopefully simple suggestions. I was thinking of replacing the viscous clutch fan with a fan from Pendy that bolts onto the flywheel. Also thinking of adding air scoops to the fenders to get more air in the engine area. Any other ideas on bringing the temp down? I was thinking of seeing if a thermostat is in the truck and removing it for the summer if there is one present. Any other ideas or help would be appreciated.
Old June 22nd, 2012, 12:39 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
have you had your radiator looked at? I had mine cleaned as some of cooling was reduced as parts were clogged - once serviced it does not go above 1/2 on the gauge anymore
Old June 22nd, 2012, 12:41 PM
First, your thermostat is not good by your description. Replace it. Do NOT remove it!!!
Second, do you know if the viscous unit is working? When hot, pull over, pop the hood and try to stop the fan carefully with a rolled up newspaper. If you can stop it, it needs replacing.
There is no need to modify the stock design at all.
Old June 22nd, 2012, 12:44 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
^^ what he said....oh, and keep the damned fan away from your flywheel!
Old June 22nd, 2012, 12:45 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
are you sure it is holding pressure?
Check all hose connections as well as the seam around the coolant reservoir. A slight crack can cause cooling issues.
Old June 22nd, 2012, 12:52 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Make sure nothing is blocking your radiator air flow. The previous owner mounted lights right in front of the radiator - removing them dropped the running temperature by 10 degrees during a 95 degree day, about to the thermostat opening temperature.
Old June 22nd, 2012, 07:58 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
do you have the fan cowl? I have heard of some that did not have a fan cowl and by adding one they decreased the engine temp.
Land Rover 110
Old June 24th, 2012, 07:13 PM
isleofbones
Mike Deery
1984 D-90
OK, I've decided to replace the thermostat and to take the radiator to a local radiator shop to be cleaned out and checked. There are no leaks or cracks in the cooling system, but there could be some obstructions in the old system. I will let you guys know how it works out, and thanks for the advice.
200tdi, tdi
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
