200tdi retrofit, what to check/service on the engine before fitting? - Defender Source
Old March 2nd, 2008, 01:18 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
For those that have been retrofitting 200tdi engines into their rovers over here in North America, what sort of checks have you done to the 200's before installing them? I've got my 200 on an engine stand now and I'm thinking about taking the pan off and checking the connecting rod and main bearings while it is there. I'll also likely change the timing belt. The compression feels good, I could spin it up to test it but I don't have the correct fitting for the glow plugs on the 200. Any comments and/or suggestions on what I should or shouldn't do to the engine before installation?
Thanks.
Old March 2nd, 2008, 07:22 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Front and rear main seals. Timing belt and tensioner. Pull the pan and reseal, I doubt that the bearings are any issue. I generally re-gasket the whole damn thing, which gets you a good look inside......but only as I am doing it for someone else.
Matt Browne
Old March 2nd, 2008, 10:43 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
While the oil pan is out, remove, inspect, clean and replace the oil pick-up strainer. Water pump inspection, cause it is easier to replace while on the stand than when the truck is put back together and they are pretty cheap for peace of mind. I would check and even replace all glow plugs as they are also very cheap to replace. Have an EGT sender put on the exhaust manifold.
My 0.02$
Pat
Kirk Lazarus, Tropic Thunder
Old March 2nd, 2008, 07:58 PM
headdamage's Avatar
headdamage
Andrew
It is a 200tdi from a disco but it came out of a LHD 110. Someone had used a 300tdi turbo to get it into the 110 and maintain the 2.5na diesel engine mounts and transmission in their original positions.
Old March 3rd, 2008, 12:51 AM
headdamage's Avatar
headdamage
Andrew
Do you have to use new main bolts, con rod bolts, and con rod nuts when you replace the bearing shells?
200tdi, engine, service, tdi
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
