200tdi Replaced nozzles idles rough - Defender Source
Old August 26th, 2015, 10:24 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
I replaced the 4 nozzles with original Bosch ones. I have now MUCH LESS SMOKE At high speed it runs smooth and power feels good. Not more powerful than before though despite the less smoke that it produces.
But, when idling it sounds like one cylinder is not contributing. I loosened the fuel nuts one at a time and it looks like engine doesn't miss so much when nut on cylinder 4 is loose. Ideas will be welcome
Old August 26th, 2015, 10:38 AM
Did you get the pop pressure set and patterns checked with the new nozzles?
Old August 26th, 2015, 10:48 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Ehhh... nope Where can I get some info on that?...
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
where did you get the injectors from is the ?
if you have no change when opening the line indicates its not popping open correctly
No Mall crawler here
Old August 26th, 2015, 10:52 AM
United Diesel over on General Washington Dr. (Alexandria) *should* be able to check the cracking pressure and spray patterns I'd guess.
If not, I have a guy (Tom Bryant) up in Maine that will do this for ~$40 if you ship the injectors to him. Shoot me a note if you want his contact info.
Old August 26th, 2015, 10:53 AM
You need to take them to a diesel shop that can adjust the pop pressures.
Old August 26th, 2015, 11:04 AM
Yeah, just went through a bunch of injector malarkey. Don't even bother messing with them, just send them off to get tested and adjusted as necc.
Blue Ridge Diesel can do it as can any of the other listed shops I believe.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 26th, 2015, 11:06 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
I thought it was looking too easy... I'll call this place in Alexandria and if he doesn't do it we'll go with Tom Bryant. Thanks guys
BTW, I got the nozzles from ebay @$208
Old August 26th, 2015, 11:40 AM
Naplm00
Matthew
before you send them out, did you fully bleed the lines? Cracking both the feed line and the drain line while the engine is running one injecotr at a time
Old August 26th, 2015, 05:58 PM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
I did but only the feed line until no more foam came out. I'll see if the return line has any air
Old August 26th, 2015, 07:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Pablo:
It sounds like your engine has a leaking injector.
This happens when an injector fails to close and constantly leaks fuel before and after the given pop-pressure that is suppose to open the injector at a pre-defined pressure.
Blue Ridge can check it or your local guys...
The 200TDI is 2 stage. so some shops may not be equipped for these... best to check first.
RDavisinVA
Old August 27th, 2015, 09:43 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Originally Posted by rdavisinva View Post
Pablo:
If the injector is leaking it must be because I assembled it wrong?... with the old ones it smoked but ran and idled smooth. Also, Is there a known shop that has the ability to service these 2 stage injectors? Blue Ridge?
Thanks!!
Old August 27th, 2015, 09:48 AM
Call Elton Wright @ Blue ridge diesel in Salem Va. Tell him Robert and I told you to call. He has a 200 tdi in an incredible 2a 109.I was in there last week.
Blue Ridge Diesel - Providing diesel engine sales, service and parts
They are bosch dealers and can service/fix you right up,
Elton's 1927 3 wheeled Morgan aero restored and first start up.
Notice rover content in background.
200tdi, ac, idle, tdi
(4) 200 Tdi Injector Nozzles Wolf Fabrication For Sale - Parts 21 January 10th, 2013 07:01 AM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
Tdi proper startup after oil cooler lines replaced artm Defender Technical Discussions 5 August 7th, 2006 11:59 PM
Searching idle, replaced stepper now what? btate Defender Technical Discussions 3 July 15th, 2006 04:30 PM
Are my 97 washer nozzles heated? P1CR Defender Technical Discussions 2 December 17th, 2003 11:54 AM
