200tdi refreshing - Defender Source
Old September 23rd, 2013, 11:43 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
200tdi refreshing
I'm doing some maintenance items to a 200tdi before fitting in the 110. Timing belt, tensioner and water pump replaced in the front along with oil seals.
Now in the back when I'm going to replace the rear main seal I notice that there are only four bolts holding the flywheel housing to the block.
Looks like there should be eight more, including the bolts at the bottom into the ladder frame. Anybody know what those ones are?
Since I have never done this before I'm wondering if I should change the clutch friction plate or the pressure plate. Pics attached for reference.
Anything else I should be looking at while I'm at it?
ID:	80598   Click image for larger version
ID:	80600   Click image for larger version
Old September 23rd, 2013, 11:55 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I cant speak to the bolts but can say since you are in there do it..
good luck with your search
Old September 23rd, 2013, 12:11 PM
Since the holes are there and counter bored for socket head cap screws, I would install them. I helps with keeping everything from squidging around. I had to modify my flywheel housing just for this very thing. Yes, all those should be filled with bolts.
Old September 23rd, 2013, 12:46 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Discovered that the bottom ones are the same threads as everything else back there. I'm running a tap through them to clean everything up a bit.
It makes me a little concerned about the rest of the engine considering there should be 200% more bolts on this one part.
Old September 23rd, 2013, 01:00 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I think the bottom ones were allen head
Old September 25th, 2013, 09:06 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Does anyone have a 200tdi air filter housing?
Old September 26th, 2013, 08:46 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is much easier to replace all of the clutch parts now.
Old September 26th, 2013, 08:59 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I went ahead and ordered new clutch bits. It will never be easier than now so I went for it.
Old October 26th, 2013, 01:34 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Now I'm on to cleaning up intake and exhaust manifolds and putting on a new gasket. Three of the exhaust ports look dry and and one of the valves appears to be leaking. Normal or ordinary? Doesn't look like a good thing to me.
ID:	82974   Click image for larger version
Old October 26th, 2013, 01:41 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Also, I'm not certain about the condition of the turbo. The thought of a runaway diesel is rather concerning so I'm wondering if there is any way to do a layman's inspection and get a reading on the health of the turbo. The whole exhaust system is rather rusty and crusty
Old October 26th, 2013, 01:52 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
What the hell? That was depressing to watch.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old October 26th, 2013, 01:54 PM
I would definitely replace the clutch, pressure plate, and throwout bearing. Its a lot easier to do it with the engine out of the vehicle. I would especially do it if you haven't driven it with the current clutch.
Old October 26th, 2013, 02:09 PM
Also, replace the pilot bushing. And the clutch fork with a reinforced one. And, definitely put in those bolts. Without them, the rear main seal won't.
Old October 26th, 2013, 02:24 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I did the clutch stuff including friction plate, pressure plate and release/throw out bearing, rear main seal and rear gasket with all the bolts.
What is pilot bushing?
Old October 26th, 2013, 02:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Goes in the end of the crank & supports the gearbox input shaft.
Mike Hammond
transientmechanic's Avatar
transientmechanic
1972 SIII
This is on the verge of shipfitters disease.
Check for play in the turbo shaft, some lateral play is OK (shaft sliding back and forth on bushings) but any wobbly play to it means its on its way out. I would not worry about the valve guide seal now.
I had my flywheel resurfaced for the new clutch with my 200tdi, not sure if it was necessary but it seemed the right thing to do. I also changed the flywheel housing to block gasket.
Old October 26th, 2013, 02:42 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Originally Posted by transientmechanic View Post
This is on the verge of shipfitters disease. Check for play in the turbo shaft, some lateral play is OK (shaft sliding back and forth on bushings) but any wobbly play to it means its on its way out. I would not worry about the valve guide seal now. I had my flywheel resurfaced for the new clutch with my 200tdi, not sure if it was necessary but it seemed the right thing to do. I also changed the flywheel housing to block gasket.
Lol. I'm afraid so. This is the first time I have done any of these things and there have been a few red flags so far when looking it over so now everything that looks out of whack makes me question the whole lump.
Thanks for your patience.
Old October 26th, 2013, 02:53 PM
Adam, I've always been advised that on a cold engine there should be some perceptible radial play in the turbo shaft (wobbly as you refer to it). This to account for expansion when hot and provide clearance for oil to flow around the shaft as it is supposed to.
Old October 26th, 2013, 03:03 PM
transientmechanic
1972 SIII
I have heard conflicting reports on that. Typically there are some discrepancies depending on how big of a turbo you are working with. The 200Tdi T25 is microscopic compared to most gas engine turbos. I think that any play beyond a barely perceptible amount may be cause for concern... but I am definitely not a Tdi turbo expert.
Old October 26th, 2013, 03:15 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
After looking closer at mine there is a tiny bit of play along the shaft but much more in the wobbly direction.
Adding A/C to a 200tdi Defender dave_lucas Defender Technical Discussions 35 October 3rd, 2015 03:41 AM
1985 LHD 110 CSW 200tdi broadstone For Sale - Vehicles 2 September 1st, 2012 11:33 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
