200tdi rear crank sealing area size - Defender Source
Old June 20th, 2016, 07:45 AM
Naplm00
Matthew
Well all this talk of crank seals has mine now leaking slightly more than profusely.
I'd like to fit a speedi sleeve when I seperate the Trans and engine, or at least have one on hand.
Can someone with access to a 200tdi or 2.5na please measure the size of the crank for me at the sealing surface and possibly give me a depth as well?
That be swell... Pretty please?
Old June 20th, 2016, 08:40 AM
I would suspect the seal has failed and not the crank surface.
Old June 20th, 2016, 08:46 AM
Naplm00
Matthew
Yea prob but I just want to be safe
Old June 20th, 2016, 11:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Delete
Old June 21st, 2016, 10:27 AM
Naplm00
Matthew
Ne body?
Old June 21st, 2016, 10:49 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'll go take a look at my spare engine,
Old June 21st, 2016, 10:55 AM
Naplm00
Matthew
Thx man
Old June 21st, 2016, 11:25 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
pics
waiting on a cailper to get the other measurement
is it me or does this look different from my other 200tdi? its out of a Disco
ID:	152303   Click image for larger version
Old June 21st, 2016, 11:27 AM
Naplm00
Matthew
Na looks fine, you just don't have the rear cover on there
Old June 21st, 2016, 01:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
3.915 inches on a caliper by a mechanic
Old June 21st, 2016, 02:35 PM
Naplm00
Matthew
Well shit, looks like there is no longer a size that will fit. Thanks anyway.
Scotchbrite here we come.
Old June 21st, 2016, 02:38 PM
Are you positive it is the seal leaking and not the "gasket" between the block and clutch cover?
Old June 21st, 2016, 02:40 PM
Naplm00
Matthew
No, I'm not, also not even sure if it's the seal lip to crank or outer seal to housing. Haven't taken it apart yet.
That being said, I'm getting oil from the wading plug hole only, not anywhere on the outside of the engine or weeping from the rear clutch cover to block area.
I'm planning to use locktite 620 bearing mount on the outer seal to seal housing this time around
Old June 21st, 2016, 03:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I did mine twice, it was a huge PIA.
Second we did use a sealant on the seal
Old June 21st, 2016, 03:29 PM
Naplm00
Matthew
Yea I'm going to do it the cheater way this time. Remove floor and hump and drop front of rear drive haft. Unbolt and shuffle back Trans and tcase on Crossmember then replace.
Old June 21st, 2016, 03:34 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Tough part will be driving the seal in square with crank coming through the center. Make sure to use the plastic sleeve when you slide the seal over crank.
~ Semper Fidelis ~
Old June 21st, 2016, 03:38 PM
Naplm00
Matthew
Yea I'm thinking Im going to use a piece of 4in pvc pipe and a flat piece of plywood to hammer it in. Sleeve on the crank with the seal lip greased with moly engine assembly lube and the outside with loctite bearing mount
200tdi, tdi
200tdi rear crank seal tomaco1 Defender Technical Discussions 7 December 21st, 2015 11:03 AM
200tdi injector sealing washer? tomaco1 Defender Technical Discussions 7 September 8th, 2015 08:58 PM
200tdi rear crank seal D90user Defender Technical Discussions 3 March 23rd, 2011 02:50 PM
300tdi crank timing gear thread size Ren Ching Defender Technical Discussions 4 February 12th, 2011 10:19 PM
Sealing Rear Wheel Well Bolt Holes Boone90 Defender Technical Discussions 10 February 18th, 2007 01:30 PM
