200tdi rear crank seal - Defender Source
Old December 21st, 2015, 09:12 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I finally got around to swapping out my clutch fork and clutch on my 200tdi.
installed a New rear crank seal and gasket between the flywheel housing and block, while i was in there.
I had always lived with(3 years,18000 miles) a slight oil drip and had hoped it would be gone after doing all this work
truck ran great, shifted better, took less pressure to depress, I was pumped, until we saw the puddle underneath the truck, it was leaking worse.
What could it be? what steps did I forget.
One question I had was, That since the flywheel bolts go all the way through the crank, will the oil find its way through the bolts?
Old December 21st, 2015, 09:28 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Nope..
Old December 21st, 2015, 09:38 AM
I have a leak as well after doing my rear main, although it didn't leak immediately after the change...about 3-4 months after. I used the genuine Dowty teflon seal. I need to go back in there and do it again...
Old December 21st, 2015, 09:47 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
mine didn't have a flywheel reinforcing plate for some reason, was wondering if thats a problem?
also saw mention of some t seals but wasn't sure if that was 300 only
Old December 21st, 2015, 09:55 AM
No idea.
My theory is that I didn't install the seal "dry" (I applied oil to the crank surface and seal before installation) and that screwed it up.
My next go-around, I'm going to install it completely bone dry and see how that fares.
Ah, the old counterfeit 200tdi rear main seal trick!!! Been there done that. You must buy the Dowty lip seal made from Teflon or else you will be hating yourself.
Old December 21st, 2015, 09:58 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Two hundies just have the seal, no plate
One thing trailer fitter didnt mention is not to finger the Teflon lip of the seal. (edit) fitted dry as far as I know, which in the dozen or so have been
Sure sorry you need to pull it again, good luck.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 21st, 2015, 11:03 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
mine was $60 and came in a land rover box, i hope that wasn't the wrong one to use
200tdi, tdi
Front crank seal R&R Qs DefenderMd Defender Technical Discussions 0 June 21st, 2015 08:35 PM
WTB-200tdi crank pulley D90user Wanted 11 June 25th, 2012 01:44 AM
Crank shaft Seal Zooben1 Defender Technical Discussions 3 May 18th, 2011 09:56 PM
200tdi PS pump , Rad, and Crank pulley tomaco1 Wanted 3 April 17th, 2011 04:06 PM
200tdi rear crank seal D90user Defender Technical Discussions 3 March 23rd, 2011 02:50 PM
