200tdi rad cap pressure - Defender Source
Old May 3rd, 2011, 10:09 PM
Naplm00
Matthew
What is the LR factory pressure cap release at? My cap is shitty and is a 9lb (60kpa) cap. Seems a bit low?
Old May 4th, 2011, 02:36 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Pretty sure it's 15psi/1 bar for the 200TDi, regardless of metal or plastic cap. The 9 psi caps were for the 4 cyl gas engines.
Tony
1984 110 "Smokey" (sold)
Old May 4th, 2011, 07:03 AM
Naplm00
Matthew
Nice if someone could confirm. Any leads on a domestic equivalent?
Old May 4th, 2011, 07:55 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
For the 200Tdi it's part # NTC7161, and indeed is 15psi.
Old May 4th, 2011, 08:55 AM
Naplm00
Matthew
Great thanks guys
200tdi, tdi
200Tdi Oil Pressure Switch John_Karlsson Defender Technical Discussions 1 June 20th, 2010 02:04 PM
Center Dash part/ 200tdi Oil pressure tomaco1 Defender Technical Discussions 3 January 18th, 2010 09:42 PM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
» Defender Registry
QQ Rover
MLP141
NAS D90
Sned
Add your Defender
