200Tdi Pulleys - Page 2 - Defender Source
Old September 12th, 2016, 07:55 PM
Originally Posted by LostChord View Post
Got it - thanks again Doug. You guys are amazing.
Another quick question: When I gave it a few quick turns tonight before running out of time, the pulleys/belts rotated on a couple of those turns as I tightened the nut. Is this normal?
I'm pretty sure the pulley is off of the key. Looking at some pictures reminded me the key is quite short.
Personally, I would lossen the belt and take the pulley off and have a look into where the key is and see if it looks alive or dead and try and get the pulley aligned and all the way in. The pulley should press hard into the timing belt pulley.
This picture is what it looks like with the timing cover out of the way. The front pulley covers the rest of the crankshaft.
Old September 12th, 2016, 07:57 PM
The timing belt pulley and the front pulley share the same woodruff key. If it comes loose, it will be bent pushrod time.
Old September 12th, 2016, 07:58 PM
Originally Posted by rdavisinva View Post
We have the special tool to hold the crank pulley.
I thought you got one too, UD.
Looks to me like Brian's PS pump doesn't protrude through the plate enough to line up, but the pictures are so bad, it's very hard to tell.
yep, you gave me one and I use it, but that tool is useless if the hub/ keyway is compromised.
Old September 12th, 2016, 08:21 PM
What you talkin about Willis!?! Those are Grade A iPhone photos!
Old September 12th, 2016, 08:35 PM
if you felt the engines compression fighting then yes thats fine. If the engine wasnt turning then the keyway may be wasted. Put the truck in lowrange first gear. Apply the parking brake and chock the wheels so the truck cant move. That will stop the engine turning over.
Well, it felt like the engine was turning over, but I'll follow the above to stop it from turning over to be sure,
------ Follow up post added September 12th, 2016 09:38 PM ------
Originally Posted by Red90 View Post
I'm pretty sure the pulley is off of the key. Looking at some pictures reminded me the key is quite short. Personally, I would lossen the belt and take the pulley off and have a look into where the key is and see if it looks alive or dead and try and get the pulley aligned and all the way in. The pulley should press hard into the timing belt pulley. This picture is what it looks like with the timing cover out of the way. The front pulley covers the rest of the crankshaft.
Ugh...thanks John. Better to find out now than learn it the hard way.
The PS belt does look like a lucky lottery winner given that it is still there.
Old September 12th, 2016, 08:38 PM
Thats a good thing
Old September 12th, 2016, 08:45 PM
Thats a good thing
Yep, and it may be fortuitous timing. After replacing the panhard rod with my youngest daughter, we took it for a spin around the neighborhood to check and admire our work. Went to make a left hand turn and could feel a problem with the power steering as it was making an unusual noise and didn't want to turn the wheels. So I pulled the parking brake, had her jump in the driver's seat and turn the wheel while I looked underneath. That's when I noticed the PS belt was slipping on the pulley and was the source of the strange noise. Other than that, it drove just fine, so hopefully no major damage or timing issues hidden in there.
200tdi, pulley, tdi
V8 pulleys ghfaris Wanted 1 December 15th, 2015 01:01 PM
Twin Groove Pulleys Smirk1010 Wanted 0 August 14th, 2011 09:26 PM
any 95, 3.9 water pump tension pulleys out there? snosrfr Wanted 8 October 28th, 2010 10:20 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 09:10 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 08:16 AM
