200tdi pressure in the fuel tank? - Defender Source
Old October 28th, 2013, 07:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Just wondering how much pressure should there be in a fuel tank? I switched to a newer style fuel filler and cap, with a passenger side fuel tank an have a load of pressure that builds up in the fuel tank. I had the cap tight and started the engine and the pressure built right up and when I opened the cap there was pressure and even had some mist/vapor.
Is this normal, and I guess I have to find a way to vent the tank.
Old October 28th, 2013, 07:54 PM
well the tank breather should have a check valve to only allow ambient air into the tank (without a check valve the breather will leak in a rollover...bad). To build up pressure in the tank (from thermal expansion and such) is usually the cap itself (kind of like a coolant pressure cap). If you are building up pressure, you have the wrong cap. you are talking positive pressure, and not vacuum pressure, correct?
Mark Kellgren
KM4BOR
Old October 28th, 2013, 08:00 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Positive pressure
Old October 28th, 2013, 10:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Are you running 1 or 2 fuel tanks?
If so is it possible you are drawing fuel from 1 tank and returning it to a different tank?
The only other thing I can think of that would cause it would be to fill up when it's cold and remove the cap later when it has warmed up outside.
RDavisinVA
Old October 28th, 2013, 10:36 PM
Put old style cap on. Does that solve the problem?
200tdi, fuel, fuel tank, tdi
Fuel tank pressure with a 200tdi tomaco1 Defender Technical Discussions 2 September 18th, 2013 09:01 PM
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
