200tdi P/S pump w/o tensioner? - Defender Source
Old May 3rd, 2010, 12:26 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does anyone have a 200tdi without the funky tensioner setup? I used the funky setup from 2.5 petrol, and the bearings are going. The one that came with the 200tdi had no tensioner, just slotted bolt holes like you use to tension the alt. I need the part number for the belt that doesn't use the tensioner. The bearing kit is $55 so a belts cheaper and just seems easier.
Old May 4th, 2010, 07:35 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I figured it out, the Power Steering pump without the tensioner is from a 200tdi Range Rover. So I quess the who engine is from a RR, I thought it sounded a bit Snooty!
After a bit of research I found out that the RR 200tdi also has the high turbo.
Disco seems to be the same.
Any thoughts on which would be better? My thought is that this setup is better because it is simpler.
Pic
http://i422.photobucket.com/albums/p...p/DSC_9142.jpg
Old May 4th, 2010, 09:29 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I have a 200Tdi and I believe to have a pretty original setup. The PS pump doesn't have a tensioner just the slotted plate with bolts. System is not perfect but work well.
Pat
Kirk Lazarus, Tropic Thunder
Old May 4th, 2010, 10:40 AM
I'm not familiar with the Disco 200TDI, but I do not see and idler for the PS pump...
http://www.difflock.com/servicing/td...tdi-6k-2.shtml The only idler is fro the A/C.
200tdi, tdi
Water pump tensioner Mike Hippert Defender Technical Discussions 22 March 27th, 2005 12:16 AM
