200tdi overheating on highway - Page 2 - Defender Source
Old August 11th, 2016, 12:53 PM
Originally Posted by BostonAndy View Post
no IR temps for this. Its only happened a few times and it's when I get into the flow of traffic and see that i'm hauling ass. gauge drops quick after I let off.
are you running an egt gauge. If temp drops quickly when you back out it sounds like this may be tied to your fueling.
Old February 4th, 2017, 12:24 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I just did a 30 min highway drive at about 70mph with my truck, heat on full, 30 degrees outside. VDO temp gauge was going up to 205-210 if I was heavy in the throttle so I was letting out of it. Around town gauge reads lower 160-180 once it finally warms up. Truck has good compression, fresh fuel system, couple month old coolant, pretty new Bearmach T-stat. Radiator fins look OK, intercooler didnt really have any oil in it, no smoke. Truck runs strong otherwise. 200TDI 1.4 t-case.
I have always been suspect of my viscous fan (if the clutch locks up).
I don't have an EGT gauge yet but maybe a fueling issue? It feels pretty strong though.
A couple minutes after stopping I used a infrared temp gun on sender housing and it said 160ish while temp gauge reading was 180. However inside vs outside I could see 20 difference
Thoughts?
Old February 4th, 2017, 12:29 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Typically viscous or water pump. I have a never used vfan if you need one shipped Monday morning.
Old February 4th, 2017, 12:31 PM
AdamSanta85
91' D90 200TDI
Water pump was off when I did the timing belt a couple months ago. It was apparently replaced maybe 15k ago, it seemed OK though.
Fan. I have never saw it locked up, I can use my finger to stop it, spin it backwards while engine is running etc. It goes spin up slowly at idle and move though.
Ill PM you.
EDIT-
Anyone have the Revotec eletric fan kit? For $235 vs about $100 for new clutch that might be the way to go. Might free up some revs and certainly some engine bay room...
Old February 4th, 2017, 03:24 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I bought a fan assembly for a Ford Taurus from AutoZone. ~$100 and only required minor modifications - like any other part you buy for a rover. Came with the air dam.
Old February 4th, 2017, 04:11 PM
Chris B
72 + D1 drivetrain =?
At highway speeds you have an incredible amount of air passing through the radiator. Surprised it overheats then.
Old February 4th, 2017, 08:36 PM
AdamSanta85
91' D90 200TDI
Right? It isn't overheating, but not cooling as good as it could be. I am going to start with the fan and maybe just do the water pump as well since it is easy enough and pretty cheap.
Old September 17th, 2017, 03:51 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Any update on this?
I have similar issues on highway, engines heats up an dis hard to
Cool down when running it down the road.
200tdi, overheating, tdi
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 11:02 AM
Need Supplemental/Highway Vehicle gtg067i Misc. Chit-Chat 24 July 12th, 2007 07:07 PM
High Idle after Highway Cruise + stalling cellulararrest Defender Technical Discussions 3 October 11th, 2006 04:05 PM
Defender highway rollovers btate Misc. Chit-Chat 1 September 1st, 2006 04:14 AM
97' not downshifting when at highway speeds... P1CR Defender Technical Discussions 3 December 12th, 2003 08:26 AM
