200tdi operating temp - Defender Source
Old December 7th, 2010, 04:25 PM
Naplm00
Matthew
Talking 200tdi operating temp
I am adding a electronic fan controller and need to know where to set for it to turn on and turn off.
I was thinking 80C turn on 77C turn off. Thats about 170 F to 176 F. Just a guess really.
What is the stock thermostat for these engines?.
Thanks !
Matthew
Old December 7th, 2010, 04:37 PM
Thanks !
Matthew
180 or 190. mine is 190
Old December 7th, 2010, 04:48 PM
Naplm00
Matthew
thank you sir
Old December 7th, 2010, 05:23 PM
discotdi
Todd Miller
Land Rover
factory thermostat opens at 88C, which is about 190F
Old December 7th, 2010, 06:44 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I would not set the fan below 200 degrees.
Old December 7th, 2010, 07:16 PM
Naplm00
Matthew
asis... would not set it to come on before 200 F?
Any particular reason?
Old December 7th, 2010, 09:21 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You want the engine to run at operating temperature and just have the fan come on as it heats up a bit, not fighting the engine wanting to run where it should be. You will be surprised how fast an electric fan drops the temp in a diesel.
Old December 8th, 2010, 12:31 AM
DieselDef
Brad Ingalls
1985 Defender
Which controller you using and where did you get it? I need to install one on mine.
Old December 8th, 2010, 05:25 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I tapped out the thermostat housing and after trying a few LR switches I wound up using one from a VW.
Old December 8th, 2010, 10:36 AM
Naplm00
Matthew
Im going to use the derale brand adjustable from summit racing it comes with a sensor and wiring
Old December 8th, 2010, 10:48 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
The X-Fan switch is easy to use and strong enough to run one fan without relays etc. That and Si is a great guy and "one of us" so please consider supporting him before Summit who only really cares about Muscle cars.
Old December 8th, 2010, 11:07 AM
Naplm00
Matthew
Got a link?
Old December 8th, 2010, 12:08 PM
Electric fan to replace my fan is a mod I fully intend to do possibly next spring. What's the best one to deal with hottest conditions? Also want one that is not hard to source if it fails while out and about.
Old December 8th, 2010, 01:27 PM
ajh
Andrew J. Hutton
http://www.x-eng.co.uk/X-Fan%2034mm.asp?MID=4
Old December 8th, 2010, 04:42 PM
Originally Posted by ajh View Post
Great link! I'll go with that controller then. What elecricall fan is recommended to control a 300tdi (equivalent) in desert conditions?
Old December 8th, 2010, 04:46 PM
Naplm00
Matthew
thats really nice peice but a lil out of my price range.
I had a flexalite cyclone 16in fan on my 1989 325i with S52 engine. It was awesome and quiet due to the curved blades. Mine was a pusher.
on the 200tdi ill be goin with asmaller fan with straight blades, they are cheaper and I wont hear it anyway. It will be setup as a puller, it is much more efficent.
Also if your doin off-roading do not use the included fan mounts that are liek zip ties through the rad core, they car wear holes in the core during rough service. Get some cheapie brackets and use the thrucores as a emergency backup.
Spal, and flexalite are two good brands
Old December 8th, 2010, 04:58 PM
Thanks. Also found Buck's thread here on fan's for diesels: http://www.defendersource.com/forum/...ectric+fan+tdi
200tdi, tdi
Anyone know the thread size on a 200Tdi coolant temp sender? Turbofan Defender Technical Discussions 7 June 25th, 2010 01:07 PM
200TDI running temp tomaco1 Defender Technical Discussions 7 July 4th, 2009 11:08 PM
disco 200tdi temp sender D90user Defender Technical Discussions 2 February 1st, 2008 09:18 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
