200tdi Oil Pressure Switch trip point - Defender Source
Old March 13th, 2014, 11:24 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Does anyone know what pressure the stock switch opens at? I replaced mine when I added the oil pressure gauge with one I had on the shelf of an unknown pressure rating. Would like to order the correct part. And I cant use the stock part. The threads are all 1/8"npt now.
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 14th, 2014, 05:22 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I am not 100% sure what you're asking, but I think it has to do with the low oil pressure warning light.
The exact operating pressure typically is 5 - 7 PSI.
If you now have 1/8"npt, go to any domestic auto supply and order a idiot light sender for a 1978 - 1983 Chevy Monza. Screw it in and connect the single wire.
RDavisinVA
Old March 14th, 2014, 08:37 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Thats what Im asking... Thanks. The switch I put in closes at about 10-12 so at a warm idle the light is flickering.
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 14th, 2014, 09:57 AM
This link: http://www.autopartoo.com/oem/unipart/PRC6387GEQ.html says 0.5 bar, 7.5 psi.
Old May 17th, 2015, 03:33 PM
BlackField's Avatar
BlackField
Oscar
D110
Quick question: Based on that small schematic is this switch normally open or normally closed when the oil system is pressurized? I'm guessing its normally closed without pressure, completing the circuit to the light. Just checking.
Old May 17th, 2015, 09:07 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
switch is normally closed and opens on a rise in pressure.
Ryan
84 110SW County LHD
07 L322 Vogue
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 05:10 PM
Oil Pressure Sending Unit 61rover For Sale - Parts 1 September 24th, 2009 10:24 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Rocker Covers off thug1313 Defender Technical Discussions 9 April 30th, 2005 09:37 AM
