200TDi oil pressure issue - Defender Source
Old July 16th, 2016, 09:34 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Noticed this a few weeks ago and am just getting around to doing something about it. At idle warm, oil light started to flicker. Raise speed ever so slightly and goes out immediately. Connected a test gauge: 8 psi at idle, increases to 35 without much rpm (don't know exactly how much rpm). Odd thing is this: holding steady increased rpm, or even just above idle, oil pressure reading will rise up about 8 psi and then come back down. Pressute goes up and down smoothly, and seems like same rate even at a higher engine speed.
Thoughts?
Email is
Same place, new dogs.
Old July 16th, 2016, 10:09 PM
Naplm00
M
This is exactly what mine would do before it nuked the bottom end....if you can pull the fuel pump plate and the other side cover plate and check to see if any of the cam bearings have walked out of thier journals.
Also check the turbo for possible leaking seals.
I thought I had a bad oil pump and replaced it only for it to nuke about a month later.
Old July 16th, 2016, 10:35 PM
Can bearings or worn main bearings or oil pump. I don't think anything else would hurt pressure. Turbo seals would not matter as the oil is restricted before the bearings.
Old July 17th, 2016, 07:33 AM
Trevor it almost sounds like a malfunctioning oil pressure release valve. That might be worth checking before going to far with a teardown.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 17th, 2016, 07:44 AM
Chris B
72 + D1 drivetrain =?
Had a mini that would do the same thing.
Think the ideas you have been given are great. We also dropped the pan and found the pick up partly blocked.
Old July 17th, 2016, 09:25 AM
Roverlab
Trevor Griffiths
Fitted a new crank and bearings about 4 years and maybe 5000 miles ago- extensive damage due to 2 loose crank pulleys prior to coming to my shop.
Did not replace cam bearings at that time- there is a longer backstory that drove that choice- and I believe the engine was a used unit with unknown mileage. Refresh my memory, a low turbo is a 90/110 and a high turbo is Disco?
Just returned from a trip to Yellowstone- in a LR3, not the 110-, so will get a chance to look into the oil pressure relief this week.....
------ Follow up post added July 17th, 2016 10:26 AM ------
As always, thanks everybody for the input!
Email is
Old July 17th, 2016, 09:33 AM
Naplm00
M
Low turbo is disco, high turbo defender
Old July 17th, 2016, 09:35 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Generally, a low turbo is a Disco and a high turbo is a Defender but these can be reconfigured with different manifolds.
Best way to tell:
11L - Defender 200Tdi
12L - Disco 200Tdi with manual gearbox
13L - Disco 200Tdi with auto gearbox
200tdi, tdi
oil pressure gauge issue aosias Defender Technical Discussions 0 September 28th, 2013 08:48 AM
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 04:10 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 02:16 PM
200Tdi Oil Pressure Switch John_Karlsson Defender Technical Discussions 1 June 20th, 2010 01:04 PM
Center Dash part/ 200tdi Oil pressure tomaco1 Defender Technical Discussions 3 January 18th, 2010 08:42 PM
