200tdi need help with bluish smoke - Defender Source
Old March 24th, 2010, 10:57 AM
snowkistdynasty's Avatar
snowkistdynasty
Jared Stone
1984 Defender 110
I have a 200tdi, I drove it from NC and when I was almost home (Utah) It started to smoke bluish smoke. I was using the gears to slow me down as I came down a big pass here. All of a sudden it just started to blow out lots of bluish smoke. I thought it was piston rings, from knowing a little about gas engines. I took it to a mechanic, he said it had great compression over 400lb each cyl. But it also had what he thought to be oil on the glow plugs. I was wondering if elevation has anything to do with it. The 200tdi went from 400 ft above sea level to 5000 ft. I don't have any idea how to adjust the injection pump. I have changed the fuel filter. It ran hot almost the whole way home but the temp gauge was a little faulty, but since having it I have replaced the radiator. It had holes it the top of it. I am also wondering if the valves are bad. How do you check those? any help would be appreciated. Thanks guys.
Old March 24th, 2010, 01:11 PM
Yeah, compression can be good but if the valve guide seals are blown you'd definitely be pushing smoke. Try new seals first and see where that leaves you.
Old March 24th, 2010, 01:22 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Oil on the glowplug/s could just mean that that particular glowplug isn't working, and hasn't burnt any oil off of it. Tdi's will start easily with no pre-head.
Valve seals are easy to change, so a good starting point.
Old March 24th, 2010, 01:31 PM
exmod110's Avatar
exmod110
Don Lang
can also be turbo seals leaking... has it done it since? can pull off the intake hose and check for oil there....
85 exmod 110 rhd 300tdi
Old March 24th, 2010, 04:28 PM
snowkistdynasty
Jared Stone
1984 Defender 110
The mechanic said it was miss firing. At a low rev, all the cyl are not firing. Sorry I forgot to mention it before in the first post. would bad valve seats cause it to miss fire? I live in Utah, would a shop have the seats or could I do it myself? If so where would I get seats? Thanks for responding so fast guys.
Jared
Old March 24th, 2010, 04:57 PM
exmod110's Avatar
exmod110
Don Lang
2 things,1 Was it "hot" at any point.. as you said the temp was high? Pos head-head gasket concern from getting hot.. if it is not using coolant or pushing it out then not likely.
2 if you have good compression readings.. less then 10% difference between all cyls... with a misfire I would be looking towards a bad injector.... bad valve stem seals will not cause a miss... esp with good and repeatable compression readings. blue smoke yes misfire no.
Old March 24th, 2010, 05:35 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
If you are at high altitude and not using the go pedal at all while going down a hill you will get loads of white smoke, that's very normal. But it sounds like it continued on the flat and while under power. I would suspect the timing..
Compression isn't happening at the right time.
Keith
Big, Red and ... aaa Red..
Old March 24th, 2010, 06:56 PM
Check the timing. Smoke on overrun is usually retarded timing, but can be a bad injector or pump as well.
Old March 24th, 2010, 07:07 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would have the injectors checked and do the valve seals at the same time. Then take it from there. Also check the timing. Do you know when the belt was changed last?
Legend in My Own Mind.
Old March 24th, 2010, 08:19 PM
snowkistdynasty
Jared Stone
1984 Defender 110
No, it doesn't use any water, I think the head gasket is fine. From the sounds of it what people are saying, I think I will start with the injectors first and then do timing and then do valve seals.
I don't know when the timing belt was last done, I figured if I did the valve seals I would do the timing belt at the same time.
Old March 24th, 2010, 10:33 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
To make a valve seals replacement, one need to lift the head out? and if so that head need to be checked for flatness in a shop. It might warp and you might need to have it cut back to flat. Then have a proper head gasket (right thickness). Am I mistaking on that? I think I remember have seen someone using an air line to stick that valve while removing the springs... Memories have a tendency to play some tricks!
Old March 25th, 2010, 07:16 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
hows your oil level? i blew the turbo on my 300tdi and it sucks up your oil and burns in your exhaust
3rd low and BOOT IT
Old March 25th, 2010, 03:11 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
If your timing belt is getting ready to fail you might end up having to do the valve stem seals.... And the valves...
Keith
Old March 25th, 2010, 04:11 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
First rule of a timing belt with undocumented mileage, CHANGE IT.
Old March 26th, 2010, 01:43 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Quoted for truth.
200tdi, tdi
Puffs of black smoke devinchi Defender Technical Discussions 10 December 31st, 2008 09:05 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
