200tdi mystery misfire - Page 2 - Defender Source
Old March 13th, 2013, 03:11 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So is that cyclinder always an issue? The rest were cake.
I just took my time and was very easy with the ratchet. it came out and the new one seated fine. i threaded it in and out a few times as i went to make sure I didn't bugger up and threads.
A little anti sieze on the new one and snugged it on down. no problems
Old March 13th, 2013, 04:37 PM
bossman429's Avatar
bossman429
Adrian
1988 90
While everything was accesible I also checked the timing.... i dont have a timing kit but its very easy to eye up the flywheel notch... i used an 11/32 drill bit which is very close to 9MM for the pump.... everything was dead on so I dont think timing is the issue.
all fingers pointing to this injector......
I thought about advancing the timing a bit but figured one thing at a time is a better approach.
Old March 13th, 2013, 09:33 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Glow Plug seizing in TDI head...
Originally Posted by bossman429 View Post
So is that cyclinder always an issue? I just took my time and was very easy with the ratchet.
No cylinder in particular is an issue, just ones with excess carbon buildup that always seem to seize the glow plug in place. The source of the extra carbon could be excess fueling, but not always.
I've gotten to where, every time I change the oil, loosen each glow plug about to flats and retighten it just to be sure they don't seize. It really doesn't take any extra time because you have to wait for the oil to run down the pushrod holes so you don't overfill and spill. A few flats won't damage the 12V glow plug wire so leave them connected. Also am careful not to over tighten... tight is tight and tighter is not better.
RDavisinVA
200tdi, fire, misfire, tdi
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Defender in Paris, and Mystery Guest Doug Misc. Chit-Chat 20 June 18th, 2004 01:52 PM
That mystery box by the gas tank. wicks Misc. Chit-Chat 7 April 2nd, 2004 07:43 PM
