200Tdi Mystery Knock - Page 3 - Defender Source
Old June 21st, 2016, 09:40 PM
87 D110 (Ruby)
man that is a FAST idle...timing is off I think
Old June 21st, 2016, 10:28 PM
eh? I think it is a little fast too. But timing won't make it idle faster. It'll just make it run like shit and make lots of smoke.
I used the iPhone audio app to see if it would pull a reading off the video. Seems to be in the 850 range. Should be closer to 750.
I don't hear anything that sounds like a rod knock. Hard to tell from internet video but if you are getting a different response on that cylinder with different injectors, then you should just send them off to get tested.
From the somewhat disorganized and limited information you've provided, I'm putting my money on injector issues.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 21st, 2016, 10:43 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Hey, If I knew what I was doing I wouldn't be asking you guys Thanks again.
Old June 21st, 2016, 10:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We have injectors, if you need any.
BE CAREFUL removing them.
Keep the wrench, pliers, vice grips away from the area where the spill over washer seats...
Turn then clockwise only.
Best of luck, Gene.
That is all.
RDavisinVA
Old June 22nd, 2016, 03:38 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Took the injectors in for testing, they're bunk. #3 being the worst which is why, i assume, in the "cracked" video there is no, or minimal change in engine sound at 4 which has inj 3 in it.
Yep, the idle is too fast also, I had cinched the throttle cable too tightly at the bracket
Looks like Robert has another customer...
Hopefully it isn't a compound problem.
Old June 29th, 2016, 03:23 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Well, it did need new injectors and it does run better with the new installed. It was noticeably more peppy on the short test run but they were not the source of the knock. At idle it is still audible, a slight revving while parked and it sounds great. Under load it's a different story, knocking loudly. I assume that only leaves the bearing option. I thought maybe it was going to be easy....
200tdi, big end bearing, engine knock, injectors, tdi
200tdi engine knock video halp!!!1 Naplm00 Defender Technical Discussions 21 April 21st, 2017 12:38 PM
200tdi Mystery coolant loss AKTOS Defender Technical Discussions 26 July 23rd, 2015 05:18 PM
Mystery Coolant Loss - 200TDI Howski Defender Technical Discussions 15 May 31st, 2013 10:59 PM
200tdi mystery misfire bossman429 Defender Technical Discussions 22 March 13th, 2013 09:33 PM
Continous Knock Fault chrisconnie Defender Technical Discussions 5 September 10th, 2007 08:28 PM
