200tdi Mystery coolant loss - Page 2 - Defender Source
Old July 14th, 2015, 07:46 AM
minor difference in the casting. The later one has smaller coolant passages. Makes no difference as the head gasket deliberately restricts flow.
If anything, the one with smaller holes is probably better as there is more metal there.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 14th, 2015, 08:09 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Wow, thanks for sharing. Even at 35km's there's no grace. It's important, IMO, that when experiences like this are shared in public it helps keep overall prices in check. When you think about it 20+year old engine swaps @ $10k a pop is no joke.
Old July 14th, 2015, 08:14 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by AKTOS View Post
Finally took the head off and had it tested (will post photos later) and it is cracked somewhere internally, it allows coolant in the exhaust. Mainly when the engine is off water enters the cylinder No3. Fortunately damage is minimal.
Perfect example of the fragility of the 200TDI head.
RDavisinVA
Old July 20th, 2015, 07:18 PM
AKTOS
Yannis
1989 LR 90 td conv 200tdi
Ok, got that other head, seemed in very good condition even though I only paid €320.00 for it, got it tested was good, planed it & re-seated the valves, drilled the small water passages to 9mm because the climate here is hot, installed it, changed the oil, cleaned the injectors preventatively, GOOD TO GO. Water pressure and temp normal, Runs perfectly again!
For how long? I wonder!
THANKS OVERYONE FOR THE SUPPORT AND ASSISTANCE!!!
Old July 20th, 2015, 07:24 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Good to hear it all worked out.
Where did you get the head from?
Old July 21st, 2015, 05:23 PM
AKTOS
Yannis
Hey Scott,
Over the years I've known garages who have been servicing Land Rovers but not exclusively. I just started calling around and found this one and one more reconditioned and quite more expensive; €1.000. I chose to take my chances with this one. It had just been laying around at this garage for a while, I don't know how it ended up there and for what reason it came off the engine it belonged to but didn't much care since a visual check and pressure testing would reveal any issues and prove worthiness. The agreement was that I could return it within 10 days if it tested unworthy.
I figure that I saved ~€400 over the reconditioned one plus more confidence as I got to see and inspect it before the machining work which was done by a shop I trust & got to watch the whole process.
Old July 23rd, 2015, 05:18 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Turner is a very reliable source for heads should you need to go down that road again.
Turner Engineering - Remanufacturer of Land Rover Engines and supplier of Land Rover engine parts
200tdi, coolant, tdi
Coolant loss ? keep an eye under the pump JFD Defender Technical Discussions 2 November 11th, 2014 04:43 PM
hot cocoa on the ground- instantaneous loss of coolant delosanasazi Defender Technical Discussions 5 September 13th, 2014 10:39 AM
Mystery Coolant Loss - 200TDI Howski Defender Technical Discussions 15 May 31st, 2013 10:59 PM
TDI coolant leak scooby doo mystery Overlander Defender Technical Discussions 19 January 14th, 2011 01:42 PM
Coolant leaking into cylinder mystery jaherring Defender Technical Discussions 9 April 17th, 2007 07:55 PM
