200tdi massive black smoke on .. - Defender Source
Old May 16th, 2010, 09:02 PM
Rugbier's Avatar
Rugbier
Gustavo
When running the between gears mostly between 1st and 2nd and when comming to a turn from 5th/5th to second there is a massive amount of black smoke.
Is it too much fuel going in? should be adjusted and how?
Ideas, suggestions to correct it?
BTW, clutch was adjusted, still no more than 5/6 lbs of boost. ( check all hoses ), Trevor noticed a small puff comming at start up from the Downpipe ( halfway down the elbow behind the turbo where the flange is.
TIA
NO SIGNATURE
Old May 16th, 2010, 09:50 PM
If you are not producing boost you need to check that first... Check for a boost leak. You can pressurize the intake system and look for any leaks. Is the boost control line to the injector pump OK? Is the boost control diaphragm in the injector pump good?
Old May 16th, 2010, 10:01 PM
Rugbier's Avatar
Rugbier
Gustavo
Control line is new.
The Diaphragm, well ...... I have read about it and I have as well read that it is very easy to screw it up and I am wondering if I am qualified to do it.
NO SIGNATURE
Old May 16th, 2010, 10:09 PM
Can't see how you could screw it up. Unscrew 4 flat head bolts, pull cover. Mark the angular position of the diaphragm so that it can go back in if it is moved. Check diaphragm for splits, holes, breakage, whatever. You can pull it out to inspect, with the rod. You probably need to turn it to get it fully out, just turn it back to the original spot after you put it back in.
Like, I say, check for boost leaks first. The blower end of a shop vac into the inlet of the turbo should work...
Old May 17th, 2010, 09:31 AM
Gustavo, Bring it by and I'll take the IP back to the stock settings for you. I'm back in town. The diaphragm John references is marked with a black perm marker. There is a mark on the housing and an arrow on the diaphragm. Line them up and you are @ the stock setting. I would suspect another problem however. Have you changed the fuel filter since you got the truck from me ?
Old May 17th, 2010, 10:27 AM
Rugbier's Avatar
Rugbier
Gustavo
Doug,
No I did not change anything ( I only put maybe 1,000 miles )
Would be great if you can help me, do you know the fuel filter part number and from where to order?
Maybe you can help me trace the loss of boost ? ( I know I am pushing it *LOL* )
What day and time works for you?
Tomorrow would be my best day ( even maybe today ? but I have no filter with me? )
NO SIGNATURE
Old May 17th, 2010, 10:37 AM
Originally Posted by Rugbier View Post
Doug,
Tomorrow is no good- have to be in a business meeting in NJ most of the day. All tdi's use the same fuel filter. Think I just used my last spare but will double check- I have changed mine twice since Feb as I continue to clean things out (you should keep a spare handy-never know when you will get some bad fuel). That truck never showed more than 8-9 pounds of boost @ 3000 rpm. Keep in mind the reading is coming from the intake manifold not @ the turbo. So if you are seeing 5-6 and its not running right, lets check elsewhere.
Old May 17th, 2010, 10:51 AM
Rugbier's Avatar
Rugbier
Gustavo
Let me know when we can meet. ( I'll make it happen )
The funny part is it gets to 5-6 and then drops , then builds up again.
NO SIGNATURE
Old May 17th, 2010, 10:55 AM
sounds like its over fueling or the fuel isn't atomizing right
Old May 17th, 2010, 11:02 AM
Rugbier's Avatar
Rugbier
Gustavo
Remember you are talking to Gustavo, what would that translate in English?
NO SIGNATURE
Old May 17th, 2010, 12:51 PM
Doug,
FYI I just ordered one up from George @ RDS for $20 as follows:
Bosch Fuel Filter
200/300tdi
AEU2147L $20.00 http://www.roversdownsouth.com/defender-engine.htm(it's at the bottom of the page)
I think he has OEM as well.
Old May 17th, 2010, 01:53 PM
Rugbier's Avatar
Rugbier
Gustavo
I was going to call Loco Jorge, but someone has couple of this locally
http://www.roversnorth.com/store/p-6...00300-tdi.aspx
NO SIGNATURE
Old May 17th, 2010, 02:14 PM
Nice, wasn't sure since Doug said he was out. Btw...I know you're from MD, any chance you're coming to HH @ Jay's this Thurs 5/20?
Old May 17th, 2010, 03:15 PM
It is a common diesel fuel filter. You should be able to buy them locally and cheaper.
Edit: Oh I see $10 at RN, cheap enough.
Some cross info here...
http://www.germanfilters.com/xref2_s...rch=WK+842%2F2
edit 2: If I got this right any 75-84 VW or Audi diesel and 81 to 85 Volvo diesels.
Old May 17th, 2010, 03:17 PM
Rugbier's Avatar
Rugbier
Gustavo
Yes I am comming over to Jay's
------ Follow up post added May 17th, 2010 03:20 PM ------
NO SIGNATURE
Old May 17th, 2010, 03:26 PM
While I'm at it... If you have the stock 200TDI Defender air filter housing, these are the easy to find cross references. It is very common filter in small industrial machinery.
Fleetguard AF-437KM
Baldwin PA1667-FN
Donaldson P101222
Old May 17th, 2010, 03:52 PM
Rugbier's Avatar
Rugbier
Gustavo
Yes I do.
Fleetguard AF-437KM
Baldwin PA1667-FN
Donaldson P101222
NO SIGNATURE
Old May 22nd, 2010, 11:13 PM
All better ?
Old May 23rd, 2010, 10:33 AM
Rugbier's Avatar
Rugbier
Gustavo
Yes , thank youuuuuuuuuuuuuuuuuu again.
NO SIGNATURE
Old May 23rd, 2010, 12:56 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
And what was the issue???
200tdi, ac, tdi
200tdi need help with bluish smoke snowkistdynasty Defender Technical Discussions 14 March 26th, 2010 01:43 AM
Puffs of black smoke devinchi Defender Technical Discussions 10 December 31st, 2008 09:05 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
