200tdi losing power - Defender Source
Old July 16th, 2013, 12:43 PM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
200tdi losing power
Hi all. My 200tdi 130 (only had a couple of weeks now) is losing power while driving more than about 50mph. It almost seems as if it is not sucking enough fuel. I'm guessing its a bad fuel filter of maybe a bunch of gunk in the lines as the truck was poorly cared for before I purchased it. This is my first diesel so any insight is greatly appreciated. Thoughts?
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old July 16th, 2013, 12:46 PM
Change the fuel filter and check that the lift pump is working. Remove the electrical lead from the injection pump and the inlet line from the fuel filter. Crank the engine and see if the lift pump pumps fuel.
Old July 16th, 2013, 12:51 PM
Ben01
Ben
Defender
Also check the fuel line for a leak.
Old July 16th, 2013, 03:54 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Good suggestions above. I'd change the fuel filter and air filter (if there is a question) then go from there.
Old July 16th, 2013, 05:28 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Almost certainly the fuel filter, changing it will probably fix things. If it doesn't check there is no obstruction in the fuel pick-up line. there might possibly be a fuel filter on the end of the pick-up pipe.
One dirty jerry can of fuel is enough to cause problems - been there and a new main filter fixed it. Don't run too long with a blocked filter or the mechanical fuel pump will die. This won't necessarily stop the engine though, my 90 ran with a completely FUBARed pick-up pump for a while. (Don't worry ED I put a new one on)
Mike Hammond
Old July 17th, 2013, 06:40 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Awesome, thanks guys. Fortunately I DO have a new fuel filter on hand AND just ordered all new fuel lines to go with the new fuel tank that just came in. Sounds like I'll be good soon.
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old July 17th, 2013, 09:15 AM
No worries, lol! Thanks again, Mike
To the original poster: Remove your fuel pickup line from your fuel tank. At the tip of it, you will see a little fuel filter screen (it's a small white plastic cylinder). Check to see if you have anything on the screen. Clean the filter off completely and put the sender back in the tank. What should happen is that the performance of your vehicle will be restored, but the power loss will come back when the filter becomes clogged again.
Algae bio-film in diesel fuel tanks can grow over time and this stuff will clog everything in your fuel system.
The most successful way of removing a bad case of algae in your diesel is to drop the tank, fill with Purple Power cleaner (watch out - it's nasty, lye-based stuff - it will burn your skin without protection), and let keep overnight. Fill the tank with water to dilute the cleaner and pour the contents of the fuel tank out. The algae and brown crud will come out of the tank in a big brown sheet, leaving a clean fuel tank inside.
Old September 22nd, 2013, 11:26 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
After installing a new fuel pump and pick up lines she's up and running. Getting her back to being road worthy took longer than expected...too busy changing diapers
Thanks again fellas for offering all your advice!!
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old September 22nd, 2013, 12:31 PM
mikeslandrover
Mike Hammond
Good to know you sorted it.
Mike Hammond
200tdi
200tdi low on power and smoking Sun Traveler Defender Technical Discussions 32 June 10th, 2014 06:59 AM
200tdi power steering belt tomaco1 Defender Technical Discussions 7 March 18th, 2010 01:50 PM
200TDI LHD power steering hoses RiftRover Defender Technical Discussions 10 June 15th, 2009 06:40 AM
200tdi power steering pump tomaco1 Defender Technical Discussions 1 August 25th, 2008 10:43 AM
losing power Ray Bone Defender Technical Discussions 6 September 21st, 2005 08:53 AM
