200tdi lifting points - Defender Source
Old April 16th, 2010, 04:02 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
I just got my 200TDI but not sure where to lift it, it dose not have any lift rings. Any pictures?
Old April 16th, 2010, 04:11 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
/should/ have a pair of lifting rings bolted to the head/block
can't remember now if they actually use a head bolt, or a couple of castings in the head/block area.
You'll get away easily just making up couple of bent (90 degree) 5 or 6mm plates and using 2 opposite head bolts. as long as you re-torque them correctly you'll be good to go.
Old April 16th, 2010, 05:19 PM
I would not lift from a head bolt. There are threaded bosses as Jim says front and back that are used to hold the factory lifting rings. You don't need the rings, just use any bolt that fits those holes and a big washer through a link of your chain. Or if you want to be a bit less cavalier than that you could make up your own lifting tabs and bolt those on. No need whatsoever to undo head bolts just to hoist the engine up.
Old April 16th, 2010, 05:58 PM
bcourtney's Avatar
bcourtney
Robert Courtney
I actually already fabbed up some out of 3/16 steel. Just wanted to make sure the bosses on the front and back of the head were for that pupose. They seemed a little small but after a test lift all is fine.
Old April 16th, 2010, 06:04 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Yeah, they're not as heavy as you think really, not unless you're pulling the entire drivetrain out intact.
Old April 16th, 2010, 06:43 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
which is what he's doing.
200tdi, tdi
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Recovery points on LR winch bumper? jam90 Defender Technical Discussions 18 October 18th, 2005 08:06 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Opinoins On Lifting A D-90 javelinadave Defender Technical Discussions 13 March 10th, 2004 08:50 PM
