200tdi inter cooler fan? - Defender Source
Old February 18th, 2013, 06:47 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Shayne made a good point about the inter cooler on a 200 needing help from the engine driven fan to help to cool the air in the IC.
I'm wondering how much it hurts to run a 200 inter cooler with no fan? My flex lite is mounted primarily over the radiator and has only turned on twice.
Old February 18th, 2013, 10:10 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Your probably moving when your under boost, anything more than 20mph and the wind is going to be more than the fan would pull through anyways.
Old February 18th, 2013, 11:31 PM
Everything I have heard was that there is more airflow without the shroud over the intercooler than with. Kind of like when you fully upend a bottle- the bottle neck creates considerable resistance vs a glass of the same diameter with no bottleneck.
Shroud may be better under extended low range boost situations where no air is being forced through and the fan clutch locks up but thats the only time.
200tdi, fan, tdi
Clutchless Fan Replacement for 200tdi isleofbones Defender Technical Discussions 16 July 17th, 2012 02:42 AM
300Tdi cooler fan relay gone crazy JFD Defender Technical Discussions 8 April 7th, 2012 05:54 PM
Wanted: Fan and fan belts for a 200tdi jjstahl3 Wanted 6 January 12th, 2012 04:32 PM
200TDI Viscous Fan Jackie Treehorn Defender Technical Discussions 6 August 16th, 2011 07:19 PM
