200TDI Injectors and Pump - Defender Source
Old May 21st, 2015, 03:19 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Hey Guys,
What is the deal with the 200tdi injectors?
Are they dual stage injectors?
I am looking to have mine rebuilt and based on research they have an intermediary pressure as well as a pop pressure.
I have talked to some diesel shops and they say they can only set the pop pressure and cant set the intermediary pressure.
Has anyone found anyone that can set both pressures?
Is it even important?
I know some Volkswagens had dual stage injectors (not really helpful info)
the bosh nozzles are BOSCH 0 433 175 017
DEFENDER 110 2.5L 200 TDI NEW INJECTOR NOZZLES SET OF 4 | eBay
Also if anyone has info on what a rebuild of the VE Injection pump costs that would also be helpful.
Old May 21st, 2015, 03:32 PM
Yes, they are dual stage injectors. Most shops can only set the main pressure. The only places I know of in the USA that have the dual stage equipment are the places that do the setup for VW injectors.
TDI nozzle upgrade and fuel injector FAQ | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
Injector Calibration & Nozzle Mounting (VE) - KermaTDI
Old May 21st, 2015, 04:04 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
This brings up a good point. has anyone upgraded to larger injector nozzles on 200Tdi injectors. Looks like that VW site has a good breakdown of the available sizes, but not sure if they cross to the Tdi injectors.
Old May 21st, 2015, 04:10 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by BRAB View Post
If anyone has info on what a rebuild of the VE Injection pump costs that would also be helpful.
Blue Ridge Diesel in Salem, VA does a good job rebuilding the IP.
RDavisinVA
Old May 21st, 2015, 04:54 PM
BRAB
Brandon
was recommended a place in Mass Metro Fuel Injection
Services – Metro Fuel Injection
recommended by Rover Resource ( he has had them rebuild 10-15 pumps)
talked to the guys on the phone and finally someone who knows what they are talking about.
he said they can set both spring pressures as well.
I will find out more
I have a spare discovery pump Bosch #0 460 414 069 that i want to have rebuilt to specs for a defender pump Bosch #0 460 414 080 they said this should not be a problem as long as they have the Bosch Part numbers to build it to. The pumps are the same with slightly different timing.
Old May 21st, 2015, 05:14 PM
transientmechanic
1972 SIII
Did they give you a quote? I'd like to talk to them about building a rover spec pump except with a large plunger (12mm) to deliver more fuel. Also curious about better injector nozzles
Old May 21st, 2015, 07:16 PM
BRAB
Brandon
working on it
as for the injectors i am looking to see if there is anything they can do in relation to the plunger and nozzle
200tdi, tdi
200tdi injectors nozzle CDNRover Wanted 6 August 16th, 2013 03:23 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
200TDI Injectors ajh Defender Technical Discussions 4 January 15th, 2011 01:19 AM
200tdi injectors? tomaco1 Defender Technical Discussions 2 November 23rd, 2010 02:56 AM
Source for 200tdi injectors? Hoosier Defender Technical Discussions 3 April 4th, 2009 11:42 AM
