200tdi injectors? - Defender Source
Old November 22nd, 2010, 09:12 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi injectors?
I removed my injectors and I was wondering if there is supposed to be an O ring on each injector? They seem to slide in, but there is a notch that looks like it could hold an O-ring.
Old November 22nd, 2010, 09:21 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
There is a copper washer for each injector. After you have removed the injectors, the washers will probably still be in the recesses where they came from. One of mine wouldn't come out, despite attacking it with various picks. Somebody said to upset it with a punch, but I haven't tried that yet. I just put the injector back in, and it seems to be working just fine.
John Karlsson
Hope Valley, RI
Old November 23rd, 2010, 02:56 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
^^^^ Yup, just a copper washer.
It pays to dab a little grease onto the washer, and "stick" it to the injector, then carefully lower it all into the head... it's easy to drop the washer in then catch the edge of it with the injector as you insert it, which can bend it, then it'll leak.
200tdi, tdi
Non-Lucas fuel injectors tgraham Defender Technical Discussions 1 July 21st, 2010 10:12 AM
Source for 200tdi injectors? Hoosier Defender Technical Discussions 3 April 4th, 2009 11:42 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
