200tdi Initial Maintenance? - Defender Source
Old December 3rd, 2009, 12:15 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Just got my 110 with 200tdi and I need recommendations on what checks I should do and what maintenance should be done.
I plan on changing the oil and filter, fuel filter, air filter, thermostat, fan belt, and doing a general once over. I also picked up a gasket set, so I'll replace those as needed.
Should I replace the timing belt as a precaution? The motor is from a '92 Disco with unknown mileage. It has been running a little hot (or at least that what the guage said, granted I was doing 70mph running on 35s).
Grassyass!
Semper Fi!
Old December 3rd, 2009, 12:26 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Replace the timing belt. no doubt.
A friend of mine just a a 200 where the tbelt let loose. push rods went to hell, but all the valves are OK...so far.
I would also get a real temp gauge, and EGT just to see whats going on. If the IP had been tweaked you'll want to know the EGT's.
FWIW-I dont really go above 65, the motor gets warm and strung out.
Old December 3rd, 2009, 12:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
Good to know. I've heard the first thing to be done should be the timing belt from several people.
Semper Fi!
Old December 3rd, 2009, 01:32 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Definitely change the timing belt, flush the engine with flushing oil and check the radiator, it shouldn't run hot.
What sort of fan have you got cooling things down?
Change the fuel filter and run some injector cleaner through the system. Check the water trap too.
Mike Hammond
Old December 3rd, 2009, 01:40 PM
Wolf Fabrication
Sterling Archer
'08 D3
Stock plastic fan, no shroud though. The cooling issue could be a myriad of things as you know. So I need to address some of the basic stuff first.
Semper Fi!
Old December 3rd, 2009, 03:06 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
As for the cooling issues you might want to start with installing a shroud
Old December 3rd, 2009, 03:18 PM
Abrooks's Avatar
Abrooks
Tony Brooks
When you pull the radiator, Dolphin Automotive in Springfield will do a good job rodding it.
Old December 3rd, 2009, 03:31 PM
mikeslandrover
Mike Hammond
Easier said than done. The front timing chest is different - the defender 200 isn't the same as the disco the fan and water pump aren't in the same place relative to the block.
Block is the same though.
Mike Hammond
Old December 4th, 2009, 10:15 AM
J4hand
James Forehand
83 110 200tdi
That's right with the shroud. Two of us in L'burg with Disco 200tdi's installed electric fans and ditched the viscous unit. We also bought Defender 200tdi fan shrouds and found out the hard way.
Old December 4th, 2009, 01:26 PM
Steinhagen's 110 with the disco 200tdi had a fan shroud that was turned upside down. Don't know whether it was a disco or defender one but it was real long.
Old December 4th, 2009, 03:10 PM
mikeslandrover
Mike Hammond
If its long it'll be a defender fan shroud, The engine is way back up against the bulkhead. The front of the engine is very slightly behind the front axle. Mid engined
Mike Hammond
Old December 4th, 2009, 09:33 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Def. change the temp gauge to a VDO or something too. IT will give you an accurate reading then.
Legend in My Own Mind.
200tdi, tdi
Bottle Jack Maintenance? Eric Siepmann Defender Technical Discussions 8 July 15th, 2007 12:04 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
Maintenance Manuals kolvedic Defender Technical Discussions 4 February 28th, 2006 05:29 AM
Preventative Maintenance? Tricks? Tips? Upgrades? pcscharfe Defender Technical Discussions 7 February 20th, 2006 12:53 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
