200Tdi ignition hookup - Defender Source
Old February 15th, 2014, 11:07 AM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Got my keys and ignition back and of course I removed in haste and thought I could remember how it was connected! :-/
Any guidance will be helpful...
I have four wires;
brown heavy gauge - large connector spade
brown w/ red heavy gauge - large connector spade
White heavy gauge - small connected spade
Two white one w/ black small gauge - small connector spade
I also have push button start with the large white w/ red and small gauge brown.
- On the ignition I only recall four wires being connected.... Using all post except # 4 since. I was able to confirm this recollection since it's the only post with dust and crud. I did find another small white wire with small spade connector and piggy back was connected but didn't know if it came off when I pulled the ignition.
I have searched different threads and couldn't find exact information to my wires and ignition.
Thanks in advance for the assistance gents!!
Jason
ID:	89712   Click image for larger version
Old February 15th, 2014, 12:14 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
You are in luck as i just had to redo wiring bc of a small fire. Here's my best guess (i didnt take my ignition out so i didnt see the numbers).
Single large brown 5 terminal
White wire 1 terminal
Red/white 4 terminal
Black/white 3 terminal
Brown/brown 2 terminal
Old February 15th, 2014, 03:00 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Thanks! That does seem to be the correct connection for wires! Can someone tell me if I'm missing a small fitting to go over the male end? I took off the back end of ignition and can turn the switch with a screwdriver, I'm thinking the lock smith must have missed a lil part!? The truck won't fire! But heater other aux items run but not my dash lights and what not.Does the ignition need to be grounded in some way? Thanks!
ID:	89720   Click image for larger version
Old February 15th, 2014, 05:53 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
You are missing the knobly bit that fits between the two parts. You should be able to start and drive the truck with a screw driver at this point. No need to ground the housing.
Take a few minutes and double check the wiring and PIN numbers.
The white wire with the red stripe is the "crank" starter wire. If the accessories come on, but the engine won't crank, you can try a momentary jumper between the brown/white wire (hot) and the white/red wire with the key (screwdriver) turned to the "run" position. This will jump past the internal contacts and should crank the engine.
If this doesn't crank the engine, you may have a low battery or some other issues that needs to get sorted.
The advice is worth what you paid for it.
Old February 15th, 2014, 06:07 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Originally Posted by Iamkraig View Post
You are missing the knobly bit that fits between the two parts. You should be able to start and drive the truck with a screw driver at this point. No need to ground the housing. Take a few minutes and double check the wiring and PIN numbers. The white wire with the red stripe is the "crank" starter wire. If the accessories come on, but the engine won't crank, you can try a momentary jumper between the brown/white wire (hot) and the white/red wire with the key (screwdriver) turned to the "run" position. This will jump past the internal contacts and should crank the engine. If this doesn't crank the engine, you may have a low battery or some other issues that needs to get sorted. The advice is worth what you paid for it.
Thanks the lock smith admits to a part falling out! Ha ha he's thinks it's on his work bench!? I've hooked up the wires but still not getting red battery light and other lights on dash. Auxs run and it's cranking even without ignition wires since I have the push button wired. Not sure why I'm not getting a fire? Ugh!!!
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition switch for ROW 200tdi d-90. isleofbones Wanted 0 May 26th, 2012 04:15 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
