200tdi heater hoses - Defender Source
Old August 30th, 2011, 11:09 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi heater hoses
Is there any reason you can't do away with the steel hose that leads from the water pump to the back of the engine (along the valve cover) and then feeds the cabin heater?
It seems like it makes sense with a rhd setup, but makes less sense with a LHD, WITH A new style heater.
Also, stupid ? Which one goes to the in arrow on the heater? The lead from the front of the engine, or the one that pops out of the back of the block?
Thanks.
Old August 30th, 2011, 11:50 AM
Naplm00
Matthew
I believe the back of the block is the feed, but im recalling from seeing it in a thread.
Old August 30th, 2011, 12:22 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just looked again, can't seem to find it. It's tough on the phone though.
Old August 30th, 2011, 01:15 PM
Yes, back of the head (not the block) is the supply to the heater. The one at the thermostat housing is the return. It connects to a port that goes to the bypass line.
Why do you want to lose the steel tubing? running that way follows along stock supports for the hoses. Running some other route would require making up custom supports.
200tdi, heater, tdi
Heater core hoses Cred Defender Technical Discussions 1 November 29th, 2010 09:53 AM
Complete 200tdi, hoses, cooling etc.. JPBrown Wanted 5 February 21st, 2010 11:46 AM
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
NAS 110 Heater Hoses Stmpede Defender Technical Discussions 3 March 22nd, 2009 06:37 PM
Cutting off heater hoses on 300Tdi... JFD Defender Technical Discussions 4 September 20th, 2006 09:11 PM
» Defender Registry
George
Hedgey
Jon Snow
huibae
Add your Defender
