200Tdi head gasket coolant leak - Defender Source
Old October 17th, 2010, 12:48 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Just discovered a leak from the head gasket spewing a pretty significant amount of coolant. I have an amateur question: the beginning of the leak coincided with my cranking the cabin temperature all the way up (presumable allowing more coolant flow through the heater circuit). Is is possible from some gunk to have dislodged from the heating circuit and blocked the coolant circuit causing an overpressure of some sort and therefore the head gasket leak. Are the two events purely coincidental? Note that truck is not overheating. Thanks.
200tdi, coolant, gas, tdi
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
