200Tdi Fuel Return Line Help - Defender Source
Old February 22nd, 2016, 07:59 PM
So, the low pressure fuel return line ("banjo fitting") is steady leaking where the rubber? line connects to the banjo at the connection to the injector.
Not sure what caused it, which concerns me, but the line may be cracked based on what I can feel. However, it's injector # 3 behind the breather, so hard to get s good line of sight on it.
How to fix??
Are these barbed fittings at the banjo?
What about the t-connection where it joins up with the other lines?
Thanks!
Old February 22nd, 2016, 08:05 PM
Do you have the old style with the hard plastic lines? If so, buy a new return line set. The newer style uses rubber hoses between the injectors and works better.
Old February 22nd, 2016, 08:09 PM
The cloth covered black rubber lines are crap too. I used black nitrile tubing from McMaster and replaced all the spill tubing on several trucks , eliminated the leaks. Need to buy another coil.
Old February 22nd, 2016, 08:12 PM
Yes. But the fittings are better than the old style and what you want. I used 5/32" silicone vacuum hose and spring clips. Will last forever with that in place.
Do you have the old style with the hard plastic lines?...
yes.
Old February 22nd, 2016, 08:17 PM
Originally Posted by LostChord View Post
yes.
The hard nylon line vibrate loose and can get too hot.
The new style with the flexible lines gets past the vibration problem. As above, get that system and replace the cheap hose with something better and it will be good for the rest of time.
Old February 22nd, 2016, 08:20 PM
Err3652
Old February 22nd, 2016, 08:27 PM
The hard nylon line vibrate loose and can get too hot. The new style with the flexible lines gets past the vibration problem. As above, get that system and replace the cheap hose with something better and it will be good for the rest of time.
Thanks John! - does this new style use the existing fittings?
------ Follow up post added February 22nd, 2016 08:27 PM ------
Thanks Doug - love McMaster solutions.
And happy birthday.
Old February 22nd, 2016, 08:35 PM
No. See my photo. It is a different design with normal hose barbs. You are buying it for the fancy fittings that connect to the injectors. The line from the engine to the pump is still nylon and you can leave that alone. You just want to replace the three short sections between the injectors at some point.
Oh, make sure to buy the copper banjo washers as well. ERR1304 Need 8 of them.
Old February 22nd, 2016, 08:53 PM
No. See my photo. It is a different design with normal hose barbs. You are buying it for the fancy fittings that connect to the injectors. The line from the engine to the pump is still nylon and you can leave that alone. You just want to replace the three short sections between the injectors at some point. Oh, make sure to buy the copper banjo washers as well. ERR1304 Need 8 of them.
I think I'm following - just looked it up on rovahafarm and paddock spares. So ERR3652 is one long section and three short sections...I just need the copper washers and use the same banjo bolt to secure it to the injector?
Sorry for the myriad of entry-level questions...trying to make sure I understand what to do and that I have all the parts I need before going back in.
Old February 22nd, 2016, 08:56 PM
Yes. Just buy that and bolt it up with new washers.
At some point you can replace the crappy hoses between injectors with something better.
Pull the Ccv cyclone back before installing to make life easier for access.
Old February 22nd, 2016, 08:57 PM
I think I'm following - just looked it up on rovahafarm and paddock spares. So ERR3652 is one long section and three short sections...I just need the copper washers and use the same banjo bolt to secure it to the injector? Sorry for the myriad of entry-level questions...trying to make sure I understand what to do and that I have all the parts I need before going back in.
John - I found what I was looking for. So yeah, I used the search function on the googles. Thanks for pointing me in the right direction.
------ Follow up post added February 22nd, 2016 08:58 PM ------
Yes. Just buy that and bolt it up with new washers. At some point you can replace the crappy hoses between injectors with something better. Pull the Ccv cyclone back before installing to make life easier for access.
Thumbs up - thanks!
Fuel return line popped off DefenderMd Defender Technical Discussions 5 December 20th, 2014 03:48 PM
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
200tdi fuel return advice. tomaco1 Defender Technical Discussions 4 September 1st, 2011 08:04 AM
NAS Fuel Return Line TDI Guy Defender Technical Discussions 4 July 10th, 2010 06:52 AM
