200Tdi fuel distributor injection pump springs? - Defender Source
Old June 13th, 2014, 03:10 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
Anyone know anything about 2 springs that are inside the Bosch mechanical diesel fuel injection pump?
And where to buy such parts?
Old June 13th, 2014, 03:22 PM
why would you replace the springs ? There is one that lies inside the pump lengthwise that pushes against the fuel distribution block @ the rear of the pump and one underneath the diaphragm @ the top of the pump.
Old June 13th, 2014, 06:48 PM
Axel's Avatar
Axel
jack
Hello Doug - I need to replace them because both of mine broke. And having disassembled the unit, we noticed that one of the springs had dug 2-3mm in to the block, over the years. Apparently one had broken some time ago, based on the corrosion on it, & the other only recently. This could throw the timing off significantly & explain several issues...maybe?
Would it run with only one spring in there?
Old June 15th, 2014, 02:58 PM
That being the case I'd send the pump to a bosch authorized rebuilder.
Old June 15th, 2014, 04:39 PM
Ignotus
gene
1960 109, w/200TDI
And where to buy such parts?[/QUOTE]
Try Diamond Diesel Service Inc. http://www.diamonddiesel.com/
HTH
gene
200tdi, distributor, fuel, tdi
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
200tdi injection pump (needs seals or rebuild) tomaco1 For Sale - Parts 4 August 27th, 2012 08:01 AM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
New Fuel Pump - Injection Service too? tdn Defender Technical Discussions 3 May 27th, 2011 08:44 AM
Defender 200Tdi injection pump ... Retrofit Defender Technical Discussions 2 March 9th, 2010 10:11 AM
