200Tdi Fuel Bleed Question - Defender Source
Old February 6th, 2013, 05:22 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
While priming with the lift pump I can hear air bubbles in the tank and fuel/air moving through the lines. Should this be the case, should fuel be able to be pumped through the injection pump and back to the tank by manually priming the lift pump without the bleed screw on the filter open?
Also, there is way too much air in the system to account for space, can there be an air leak somewhere without a diesel leak? I can prime the lift pump and continually hear a stream of bubbling in the tank.
The symptoms:
Will idle but stalls under load/up hill, sometimes I can rev it up but typically stalls after. starts again ok if a little rough.
I've just installed a sedimentor, new fuel filter and fuel lines from the sedimentor to fuel filter, and onward to the new lift pump.
Fuel sprays at idle when I crack line at the injectors.
This has been driving me bonkers, Thanks in advance for any input.
Old February 6th, 2013, 05:25 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well, the spill rail is what goes back to the tank, so it is possible that you can pump back to the tank using the manual lift pump handle. However, I wouldn't imagine you would have air for very long.
I am wondering if you fuel pickup line from the tank to the lift pump has a crack in it and you are sucking in air.
Old February 6th, 2013, 05:27 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
So it's possible to have an air leak on the suction side that wouldn't leak diesel?
Old February 6th, 2013, 05:29 PM
navydevildoc
Neill Thornton
Sure. The diesel isn't under pressure on that side, it's under vacuum. So the fuel would have no reason to leak out normally. Once you turn the truck off the vacuum goes away, and now you just have equalized pressure on both sides of the line. The rubber seals, and then no leak.
Old February 6th, 2013, 05:36 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Ok, I'll give that a look, thanks for the quick reply.
If anyone has any ideas on anything else to try, please add them, it'll give me a range of things to try tomorrow.
Old February 7th, 2013, 06:37 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
The new lift pump that I installed yesterday was the culprit, replaced it with another today, problem solved.
Thanks for the input, appreciated.
200tdi, bleed, fuel, tdi
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
