200TDI Flywheel resurfacing and dowel pins - Defender Source
Old February 16th, 2016, 12:39 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
I am trying to see if I purchase dowel pins for flywheel.
According to the machine shop I dropped the flywheel off to with 35 years plus of experience, they cannot get the dowel pins out and need to drill them out and reinstall them which will cost me hours of labor.
I see that there are videos of removing these dowel pins on youtube and I suggested these methods but I ended up with the comment about his 35 years of experience talk.
So, does anyone know where I can get these dowel pins?
Thanks a bunch.
------ Follow up post added February 16th, 2016 09:43 AM ------
https://www.lrdirect.com/502116-Dowel-Clutch/
Found it. Now, how do YOU guys get these suckers out?
Old February 16th, 2016, 12:44 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I'm sure plenty of places have them but I got mine from lrseries in the UK.
Sometimes you can get them out with penetrating oil and vice grips if you're lucky. If not, you just drill a small hole in the back side of the flywheel and knock them out with a punch.
Old February 16th, 2016, 12:56 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Part Number 502116, two thirds of the way down the page. RovahFarm for all your new Land Rover Parts and Accessories
Old February 17th, 2016, 07:11 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Don't you love it when an $.85 part holds up progress?
Old February 17th, 2016, 07:50 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
GM does not use dowel pins and the same is true of other manufactures.
I have encountered this same scenario with both MGs and Land Rovers.
If the shop can salvage the dowels, fine, but when they can't, I have the flywheel skimmed flat.
Only caveat is that you should use 10.9 or 12.9 bolts.
Been doing this for over 30 years without issue.
https://www.boltdepot.com/fastener-i...ade-chart.aspx
Originally Posted by DailyDrivenDefende View Post
Hi guys,
Thanks a bunch.
RDavisinVA
Old February 17th, 2016, 09:57 AM
Naplm00
Matthew
Search my thread history but I have done this exact job.
Machine shop said the same to me.
I brought it home and welded a bolt to each pin, then used a vise grip and slide hammer to pull them out. Took about 45 min with my crappy Flux core Harbor freight Welder.
I brought it back, had it skimmed and put the new dowels in. The dowels were left ina freezer overnight then quickly tapped in with a soft hammer.
------ Follow up post added February 17th, 2016 09:59 AM ------
http://www.defendersource.com/forum/...ing-34333.html
Found it!
Old February 17th, 2016, 03:08 PM
DailyDrivenDefende
Michael
Found it!
I am going to try the welding method. So these dowels are press fit? So penetrating oil won't do much good?
Old February 17th, 2016, 03:31 PM
There is a collet tool that fits over the dowels and completely clamps them in the collet. Then you put a slide hammer to it and they pop right out. Long story short, find another machine shop...
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old February 17th, 2016, 03:39 PM
DailyDrivenDefende
Michael
They already sorta mangled one of them. I have a slide hammer and a welder so well, an excuse to experiment and make my life more difficult.
Do you happened to have a picture of this collet? Just so I can see how it grabs as it might give me a McGyver moment with some of the tools I have.
------ Follow up post added February 17th, 2016 12:41 PM ------
Before I try this, does anyone see any problem trying this?
Old February 17th, 2016, 03:43 PM
Naplm00
Matthew
Press fit yes. Oil won't do anything.
Old February 17th, 2016, 04:02 PM
I like the hammer trick and the welding idea too. just keep the welding slag off the flywheel.
Present:
1987 RRC- "Chewy 2"
Past:
Old February 17th, 2016, 04:35 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Other than banging two hardened steel hammer faces together, it's works. Just wear some PPE
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 18th, 2016, 02:22 AM
DailyDrivenDefende
Michael
Folks, my attempt to remove the dowels have utterly failed. The claw will grab the dowel but there just isn't enough torque that I can apply to lever the pressed dowel out.
I walked off about 1/8 inch of out on one of the dowels but I think I am wasting time at this point with hammer.
I will try welding a bolt to the dowel tomorrow but I am wondering how I am going to attach it to the slide hammer to be effective...
Old February 18th, 2016, 08:33 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Why not drop it off at a machine shop? They'll remove them and resurface.
Old February 18th, 2016, 10:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Assuming you read post 5 and have decided you have to have the dowels, just have a machine shop drill a pilot hole from the back side that is on center and smaller than the dowel so it doesn't disturb the seating shoulder and drive the dowel out with a punch from the back.
RDavisinVA
Old February 18th, 2016, 10:33 AM
DailyDrivenDefende
Michael
You need to read it from the top and get the story.
I am in the process of getting new dowels and they are shipped. Once they arrive and if I don't have these out by then, my plan is to give the job back to them. Until then, I wanted to try to remove them myself.
My questions still remain, what would I weld something to the dowels to attach the slide hammer?
Thanks!
Old February 18th, 2016, 10:45 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Ahh sorry, seems odd they can't get it done. Seems like they should have a way to do it...
Old February 18th, 2016, 10:47 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
IF there's a will, there's a way
~ Semper Fidelis ~
Old February 18th, 2016, 11:30 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I do this all the time in my machine shop ....soo much easier
No Mall crawler here
Old February 18th, 2016, 11:52 AM
DailyDrivenDefende
Michael
I am just hesitant telling anyone how to do their job. He told me that "I have been doing this for 34 years" once already. Apparently he works with a reputable rover shop around town. Lamorna garage?
I suppose you have to create that jig to hold the dowel pin at a very specific position then drill the back of the flywheel?
My concern is how easy it would be to drill that chunk of metal.
200tdi, ac, tdi, wheel
Resurfacing swivel balls jefhuf Smaller Projects 28 September 27th, 2016 04:12 PM
WTB TDi cylinder head to block dowel Roverlab Wanted 0 May 12th, 2014 01:32 PM
200tdi Flywheel housing and Flywheel Apocalypse Vehicle Wanted 0 October 11th, 2013 06:48 PM
200tdi flywheel resurfacing Naplm00 Defender Technical Discussions 13 December 2nd, 2011 09:52 AM
Flywheel resurfacing mattm Defender Technical Discussions 2 April 9th, 2010 02:34 PM
