200tdi flywheel removal - won't come off - Defender Source
Old April 1st, 2016, 05:48 PM
richord
Richard Ordowich
1987/D90
I removed the clutch and removed the bolts holding the flywheel to the crankshaft. I put in two M8 1.25 bolts into the flywheel in the clutch holes to try to remove it but it is stuck. How can I remove it?
"Slow down and smell the diesel"
Old April 1st, 2016, 05:52 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Tap it through the starter hole to break it loose.
You may have to rotate the engine and do it a few times, but that will get the flywheel to come off.
RDavisinVA
Old April 1st, 2016, 05:58 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Mine came out without much fight. I have been using Kroil as a penetrant for my restoration project and I have to say it works better than most. Soak it and wait.
Old April 1st, 2016, 07:39 PM
Warm it up
Old April 1st, 2016, 07:51 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep.
Kroil is good stuff.
People used to tell me try some Wd-40, or try some liquid wrench, then try some PB Blaster and if tat doesn't work try Kroil.
Screw all that, go straight to Kroil.
Rent my
Old April 2nd, 2016, 12:33 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
In the great words of Shayne Young, "quit being a a bloody Pussy and wank it off!"
Old April 2nd, 2016, 05:11 PM
richord
Richard Ordowich
1987/D90
Worked!
Tapping it through the starter hole worked fine. Thanks for all the suggstions.
Old April 2nd, 2016, 06:51 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Elementary Dear Watson... good luck with your repairs.
When's that Redneck Aussie Cracker coming back here???
RDavisinVA
Old April 2nd, 2016, 07:08 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Elementary Dear Watson... good luck with your repairs. When's that Redneck Aussie Cracker coming back here???
not sure, but it's gonna be a hell of a time!
200tdi, tdi, wheel
Flywheel removal question RiftRover Defender Technical Discussions 0 January 11th, 2014 04:45 PM
200tdi Flywheel housing and Flywheel Apocalypse Vehicle Wanted 0 October 11th, 2013 06:48 PM
Key won't come out . Captain Spalding Defender Technical Discussions 7 June 16th, 2012 07:15 PM
flywheel removal galen216 Series Technical Discussions 13 July 9th, 2010 11:39 AM
How does the AC/heater box come off of a NAS 110? evilfij Defender Technical Discussions 11 March 31st, 2009 01:37 PM
