200tdi flywheel dowels - Defender Source
Old February 12th, 2009, 08:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just had my flywheel cut and they weren't able to get the 3 pointed dowels out, one came out eventually, but they just ground the other 2 down to flush.
My question is whether I should have them drilled out and find replacements for the 2 that were cut? Or can I just leave it the way it is? Use the one dowel.
Old February 12th, 2009, 09:33 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I had my 200 flywheel resurfaced without problem and my dowels remain. I suspect you can live without them, but alignment of the pressure plate is critical to getting the engine to slide back in place - you'll need a friend to hold it in place while you get the six bolts into place and snugged down.
Old February 12th, 2009, 10:05 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
thanks, mine will be out of the truck, so i'm guessing it will be a little easier.
Old February 12th, 2009, 10:29 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You need the dowels. Thats crap that they could not deal with them to surface it. I would make them fabricate some to replace the missing ones. Or just order them.
The dowels are important. Without them the assembly will tend to bring itself apart and break the bolts to the pressure plate.
Good luck
legend in my own mind
Old February 12th, 2009, 10:33 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
thanks pendy
Old February 13th, 2009, 04:19 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
They're available as a separate part, Here's one supplier here in the UK
shout if you get hassles trying to locate them, i can stick a few in a jiffybag for ya and post them over.
Old February 13th, 2009, 05:10 PM
have to agree that's bs that a machine shop couldn't get them out.
Old February 14th, 2009, 07:44 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
IF you have one, bring it to a local machine shop. they can make that no prob.
Legend in My Own Mind.
200tdi, tdi, wheel
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 04:18 PM
Will 200tdi fit LT95? Stork17 Defender Technical Discussions 8 November 8th, 2008 10:11 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
