200tdi engine removal/studs - Defender Source
Old November 26th, 2011, 01:52 AM
Naplm00
Matthew
I pulled my blown 200tdi today and noticed that 2 of the stud holes in the rear of the engine were empty. Does not look like studs have been in there for a long while.
Are there supposed to be studs here or are they just missing? Below the starter
Also are the metallic turbo gaskets reusable?
Old November 26th, 2011, 07:19 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I was thinking the same thing when mine was out, I think the ones you're talking about are behind the clutch slave thingy.
Are you going to rebuild the engine? Or get a newer one.
Old November 26th, 2011, 07:31 AM
Naplm00
Matthew
You may be right.
I bought new,the luck I've been having with this supposedly 95k engine is really poor
Old November 26th, 2011, 07:46 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I may be interested in the old one to try and rebuild at school.
Old November 26th, 2011, 07:51 AM
Naplm00
Matthew
Thanks for the offer but ill probably be doing the same, I was thinking it would be a cool Jeep engine
Old November 26th, 2011, 07:57 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Jeep engine?
Where did you get the new 200?
Old November 26th, 2011, 08:00 AM
Naplm00
Matthew
Figured I could put it in a wrangler at some point. Got the new motor from duncan at landroverimport
------ Follow up post added November 26th, 2011 08:03 AM ------
Any idea on the Turbo gaskets?
Old November 26th, 2011, 08:07 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I did new ones, I had them laying around from a gasket set I had bought. They're cheap.
Keep me in mind with the old 200..
Did you get the rebuilt, or new?
Old November 26th, 2011, 08:13 AM
Naplm00
Matthew
Rebuild, new gaskets, bearings and a fresh head
------ Follow up post added November 26th, 2011 09:21 AM ------
Hey do you happen to have the timing set used for installing the injector pump?
Old November 26th, 2011, 09:49 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I do, the one to take off the inj pump witout removing the timing belt.
Old November 26th, 2011, 05:00 PM
Naplm00
Matthew
I think I need the threaded one for the flywheel. What does yours do?
Feel like coming up one day to help me install the new timing stuff on a long block?
200tdi, engine, tdi
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
200tdi with no engine numbers tomaco1 Defender Technical Discussions 10 August 4th, 2008 05:13 PM
200tdi retrofit, what to check/service on the engine before fitting? headdamage Defender Technical Discussions 4 March 3rd, 2008 12:51 AM
