200tdi engine knock video halp!!!1 - Defender Source
Old July 31st, 2011, 04:12 PM
Naplm00
Matthew
Angry 200tdi engine knock video halp!!!1
well on my way back up from a trip to delaware I was crusing at 60 mph on the highway in 5th. I started to hear a tapping noise coming from the engine bay. It then within a moment or two of me noting the tapping becomes much louder, a knock. I pull over and cut it.
Oil and coolant mixed under valve cover, knocking gets louder and follows the speed of the engine. No smoke from tailpipe, no odd smells, oil pressure is fine at idle and when running with knock. Engine still has power.
I pulled off the valve cover and all the rockers are fine, all the push rods seem straight and the valve train functions quietly while cranking with the fuel soleniod disconnected.
Had an oil change the day before i left with Rotella T6 syn and a new mann filter. Coolant level is fine and oil level is fine. Truck has a history of using coolant and a flickering oil pressure light when at idle and the engine is hot
Video is attached.
wtf
http://youtu.be/JPqRkk2de0U
Old July 31st, 2011, 05:25 PM
oil/water foam in valve cover=very bad
Old July 31st, 2011, 08:36 PM
Naplm00
Matthew
I'm less worried about that, since I know its just a HG. The knocking is so damn loud its terrifying
Old July 31st, 2011, 08:51 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Something has let go.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old July 31st, 2011, 09:27 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I have heard of pre-detonation causing the knock?
Land Rover 110
Old July 31st, 2011, 10:42 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
I've seen a head gasket failure on a 200tdi cause water to enter a cylinder and bend a con rod.
Old July 31st, 2011, 11:52 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Well a bad injector or more can make a knock like big end bearings letting go. If you are confident that the HG has not gone on and helped destroy the engine. You could have the spray pattern checked on the injectors. Did you fill with petrol by accident?
Coolant in the engine lubrication will make a short life of your bearings. Better get it sorted after you work through this problem. Unless it already has.
legend in my own mind
Old August 1st, 2011, 02:19 AM
headdamage's Avatar
headdamage
Andrew
I thought I had this problem once... while I was speeding the engine up and down and listening with an engine stethoscope looking for the bad injector everything suddenly went to hell. Turned out it was a con rod nut that had fallen off and the remaining stud didn't like me messing with the engine, wrote the whole block off.
Old August 1st, 2011, 07:43 AM
The low oil pressure switch for the idiot light is 7psi so if you only have 7psi @ idle and a signifigant knock I would would be looking @ rod bearings.
Old August 1st, 2011, 07:46 AM
Naplm00
Matthew
NA cycled the head, valvetrain is fine and operates smoothly. Knock is coming from lower in the block
Old August 1st, 2011, 08:03 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I'd go along with Doug, and like Pendy said it doesn't take much coolant in the oil before you see rod damage. You'll be having a look inside.
Matt Browne
Old August 1st, 2011, 09:20 AM
Naplm00
Matthew
Yea I'm thinking the same
Old August 1st, 2011, 09:55 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Maybe, maybe not. Coolant in your lubrication system is an extremely serious condition and not always due to a failed gasket.
Old August 1st, 2011, 10:00 AM
Loud low pitch knock = rod big end bearing
Loud high pitch whipcrack = rod little end bearing
Typically oil + coolant will result in dispersion of oil film lubrication at the bearing surface. When that's the case, the bearings will melt out.
Don't drive it anymore. If you're lucky you'll just need to change all the bearings in the engine.
Old August 1st, 2011, 10:23 AM
Naplm00
Matthew
When I pull the head ill check under and see what cyl or cyls are full of water if any. Can the rods/pistons be removed with the engine in place? by disconnecting with the pan off?
I feel like if i have bottom end issues this large it may be better to just get a new long block
Old August 1st, 2011, 10:52 AM
Doesn't need to be full of water, just enough to melt bearings. Probably need to check if your coolant leak was a cracked block or bad headgasket.
I've done big end bearings before on Toyotas from below by pulling the reinforcing crossmember and oil pan.
There's no crossmember on a 200tdi, so pulling the oil pan should allow you to pull the bearing caps and remove the rods/pistons.
You still have the problem of the main bearings, you'll probably have to remove the tranny for that.
Back to the original problem - if you had a cracked block, then you might as well get a long block and save yourself some effort
Old August 1st, 2011, 10:55 AM
Naplm00
Matthew
Ill let you guys know, after I pull the head
Old August 1st, 2011, 01:15 PM
headdamage's Avatar
headdamage
Andrew
The ladder frame prevents the inspection and removal of the big ends from below. In addition to being bolted to the block the ladder frame should have four bolts that come in from the flywheel housing so the engine and transmission have to be parted from each other to remove the ladder frame from the block to allow access to the big ends.
However, in some tdi conversions the four bolts from the flywheel housing are over looked and you might not have them in place, in which case you can remove the ladder frame without parting the engine and transmission. Also if a con rod is bent it will not come out of the block with having part of the bottom cut off first. They are a very tight fit in the cylinder and any bend will prevent the bottom end of the rod from being moved back up the bore the way it came in. I've been through this.
Old August 1st, 2011, 02:34 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I agree the 200 tdi is a real headache to try and work on in situ. Just pull it out. If that is the direction this takes.
The water in the lubrication system needs to be addressed.
But just have the injector spray patterns checked and mark their order to rule out this as a problem and then look into the damage done to the engine with coolant seeping in. It would be more correct in the oder of things to be repaired.
You can have the oil tested for content of bearing material "melted off" as well to get an idea of where you stand with it.
Old August 1st, 2011, 03:00 PM
Naplm00
Matthew
Yea ill be sending some of the oil soup mix to Blackstone for metals. I figured this would be the easy way to find if I toasted a bearing without a full teardown
200tdi, engine, tdi
Engine Knock devinchi Defender Technical Discussions 3 January 19th, 2010 10:38 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
